CL-Class (W215) 2000-2006: CL 500, CL 600
ABS SPEED SENSOR REPAIR TIP
Old 11-04-2016, 07:15 AM
member
pmercury's Avatar
CL
Lightbulb ABS SPEED SENSOR REPAIR TIP
¨Hi
this is a contribution to help you repair your speed sensor
I changed my front bearings as they started to be noisy
in order to replace these you have to replace the seals too
those have the sensors "targets" on them
you need a hydrolic press to get them in (the best way)
then problems started
right sensor gave wrong speeds and abs, gearbox ect started to freak out and giving codes
I replaced both front speed sensors
same problem
here was the problem:
this protection plate
it's made from aluminium
in the middle, it's like 1mm close to the seal target
2 of the bolt holes where broken out and the whole thing was touching the speed sensor target seal
the engine hold in power or even worse, triggers the problems above
so this is a verry important thing to check FIRST if you have abs problems !
and will avoid you to buy new speed sensors like my dumbass me
hope it helps
additional info:
The speed sensor itself can be not centered when you bolt it in
1mm to the left or right might give you bad low speed and trigger C1037
make sure it is in centered, refer to the bolt
Plutoe (11-04-2016)
Old 11-04-2016, 01:36 PM
biker349's Avatar
cl600
great info. thanks
Old 11-30-2016, 01:49 PM
member
pmercury's Avatar
CL
More research
Problem with the right wheel sensor came back
so I connected my diagnostic tool again and reading speed live left and right
now, problem is finally solved
problem was also the seals (also tagets for the speed sensors) distance from the sensors.
what happens is when you push in the new seals with the press, you go untill it stops going in.
for some reason, the distance between the target and the sensor gets 1/2 to 1 mm to far giving intermittent bad reading
that triggers the gearbox going crazy, the abs and the eps
You car really goes crazy and then triggers faults in dash (3)
I found how to solve this and readings are really perfect now
I grinded of 1/2 to 1 mm of from where the bolt hold the sensor causing the sensor getting closer to the target.
You might not get the sensor installed correctly the first time
just grind of like on the picture, then install the sensor
if readings are bad, unbolt a little move the sensor 1/2 mm to left or right or side
you will see, there is 1/2 mm space
then try again
Personally I right side was perfect 1rst time, left I had to move the sensor 3 times
You really MUST have a diagnostic tool to read speeds live to test
the Chinese DP150E on aliexpress for 50$ will do the jub
Old 11-30-2016, 01:51 PM
member
pmercury's Avatar
CL
dont forget, if you get weird ABS BAS EPS dash messages
read speed sensors FIRST before you hang yourself
it might just be this stupid problem !
