Fault Code P20E1
Fault Code P20E1
Hi Guys
fault code P20E1 charge air coolant temperature too high, would it limit engine power once the car is only up to temp or once stored in the ECU would it limit power all the time.....
Change the intake air temp sensor and then clear the fault----if you do not do that you will notice a decrease in mileage as the ECU is being told the density of the incoming air is lower and that will affect the amount of fuel injected into the cylinders.
