Replacing Oil Leak
Replacing Oil Leak
Hello All,
Could anyone send me a pdf of the instructions on removing the oil cooler? I want make sure I dont miss anything or make my life harder. I cant get my ASRA/WIS to work. (No smartkey). Any help would be much appreciated!
On your 137 the oil\water heat exchanger at the engine block housing requires the removal of both heads, then the heat exchanger---once you get WIS working look to AR1830P3482L as the first document, there are five more you will need to do the job!!
Thanks for the advise, but would it be possible for you to PM me a pdf of AR1830P3482L? it might be a while before I get my WIS working... The old version I have says my key has expired and the new version I have needs a startkey (which I dont have).
I am already down to the timing chain & exhaust manifolds, but I was looking for what Mercedes suggests as the best way to remove the sprockets on the camshafts and the bolts from the exhaust manifolds.
