CL-Class (W215) 2000-2006: CL 500, CL 600
(2000) W215 CL500
Old 01-22-2017, 12:27 PM
Mbenthusiest's Avatar
2000 CL 500
W215 CL500 Rear End Up High
Just purchased 00 CL500 with rear end sitting high up.
Have tried to use button on dash but only front moves up and down.
slight "clunk" noise right rear going over speed bump (broken strut feel ?)
Any help is appreciated.
Thanks!
Old 01-23-2017, 12:08 AM
tusabes's Avatar
Mercedes
Whe there is a fault in the abc system the valves will lock up as a protective measure
You'll need to get it diagnosed with the Mercedes SDS computer but my guess it you have s bad strut , hoses or rear valve block
Old 01-23-2017, 12:33 AM
2000 CL 500
W215, CL500 rear end up high
Thank you for replying,
I'm hoping when I replace the rear shock that the system will work properly . any suggestions when replacing the shock?
Replace all fluid and filter?
Quick Reply: (2000) W215 CL500
