CL-Class (W216) 2007-Present: CL 500, CL 600
ABC PUMP CL550
Old 12-04-2013, 05:21 PM
Benzbias's Avatar
CL550 & CL55 AMG
ABC PUMP CL550
Need replacement ABC pump.
Any suggestions (where to buy more cheaply) beyond the dealership ($2526.00 +labour) will be appreciated. Thank you very much.
No light on dash but loud whirring noise becoming too objectionable.
Old 12-05-2013, 03:44 AM
steveb9771's Avatar
2007 CL550
Price seems high. I found a site that shows the following
ABS pump assy
MSRP Online Price
$1,540.00 $1,232.00
See http://www.mbonlineparts.com/parts/2...agramCallOut=1
Only issue for you is they do not ship to Canada, only to US for free.
You might want to check some US dealers and see if they will ship to you. The US MSRP is significantly less than the Canada price.
Old 12-05-2013, 06:58 AM
Benzbias's Avatar
CL550 & CL55 AMG
ABC Pump
Thanks Steve - yes prices in USA about 25% better - assume you mean ABC pump? part#0054667001
Old 12-05-2013, 07:01 AM
Benzbias's Avatar
CL550 & CL55 AMG
ABC Pump
Steve, what is the url of the site to which you refer? Thank you
Old 12-05-2013, 11:11 PM
steveb9771's Avatar
2007 CL550
See my previous post above for the link.
Here it is again--
Old 12-06-2013, 06:36 AM
Benzbias's Avatar
CL550 & CL55 AMG
ABC Pump
Whoops of course - thanks -
just like when I look in the fridge and cannot see the eggs ........right in front of my face!
Bought a brand new one on E-Bay ($855CDN) ships from Michigan
Appreciate your info. - will keep for next time - inevitably there will be a next time!
Cheers.
Peter
Old 12-10-2013, 04:32 PM
dmhone1973's Avatar
2007 cl550
I thought mine was going up...it was low on fluid..it was very whinny
Old 12-10-2013, 05:24 PM
Benzbias's Avatar
CL550 & CL55 AMG
Yes thanks - good suggestion - that was my hope and first thing I asked -
but alas was told the reservoir was "full"-
ka-ching ka-ching
Old 12-10-2013, 05:41 PM
Benzbias's Avatar
CL550 & CL55 AMG
forgot: Since the ABC problem occurred when depressing the brake pedal the downshifting has audibly become more noticeable?
Old 01-01-2014, 07:33 PM
stephen_clarke's Avatar
2004 SL500
Cheers.
Peter
Peter, can you share which e-bay vendor you purchased from ? I need a pump in my Sl500 in the spring. Cheapest I have seen in Toronto is $1250.00 and I did see one down in the US (anne arbour michigan) for a bit cheaper, but $855 is amazing ?
Thanks in advance
-Stephen
Old 01-02-2014, 08:10 AM
Benzbias's Avatar
CL550 & CL55 AMG
ABC
Stephen, if new, you should snap up the one you found - a very good price (compared to MB Canada) - then have McNally Motors install it - real professionals - stand behind their work. They install these pumps on a regular basis.
My discovery was serendipitous and a one-off. My purchase was not from a ongoing business with several of these ABC pumps sitting on a shelf. I took a chance that the pump was as advertised (new) and would be shipped! It arrived, was installed - so far so good. Peripherally they appear to be jobbers, buying the odd lot remnants from failed repair shops.
Having said that I just e-mailed my ABC source for permission to share his/her (husband/wife) contact info - for you to deal directly with them to determine if there is a possibility for you.
Will get back to you as soon as I receive a reply.
Surprised there is not a vibrant rebuilt pump source. Given you will replace yours later, my assumption is that your car has been "put up" for the Winter - if so perhaps you might be more cost effective to find a pump re builder - can't be much to it.
Suggest you do idler pulley at same time as part is cheap for MB (and known for failure) and the wrench will be working close by - save a second inconvenience later.
Cheers, Peter
Old 01-02-2014, 08:49 AM
2004 SL500
Peter,
Will send you a private message so we can take this discussion more 'local'
-Stephen
Old 01-10-2014, 09:55 AM
2004 SL500
Peter, any feedback from your contact ? If it helps, I'm looking for a 003 466 50 01 which may be different than the one you got.
Thanks again,
Stephen
Quick Reply: ABC PUMP CL550
