CL500 W216 Interior window door rubber trim
Hi
I hope you are well.
I have just purchased a 2007 CL500 and have a couple of questions regarding the interior rubber which sits at the top of the door against the window - not sure of the proper name. The one on the passenger side and the two at the rear seem to have the rubber missing (please see the attached image). The one on the drivers door is a black rubber as normal.
Is this normal or has the rubber fallen off?
and if so, is this a common problem?
and what part numbers could these be?
Thank you and kind regards
Kaz
Kaz
I am amazed you did not notice the missing part when you purchased the car--take the car back to the seller and ask him to replace the rubber.
I would also ask myself what else is missing behind the door panel!!
