CL500 2007 window reset? Won't lock or pinch
Mercedes CL500 (w216) 2007
Got up this morning, car windows a bit frosty and went open the drivers door. Typically the window drops a few mil, drivers and rear quarter and window pops out of seal and door can be opened.... Not this morning!
Main drivers window would not drop required few mil, had to pull open past the seal. Now car won't lock, and window will not drop automatically to allow door to shut.
When I get in the car, roll the window up, rear window auto pinches into place no probs but just no movement when use handle to open door, it's as though the soft close function doesn't exist on the driver's door anymore and in turn is not telling the window to open / close when doors are opened and closed.
Sensor? Will a reset work so you think? Any instructions how to do so? Had a look in my manual but nothing mentioned!!!
Only owned the car 6 months and few things have required attention already, beginning to think another BMW may have been a safer ( less expensive) option!
New to Mercedes but been quoted £140 from main dealer for new wheel bolts puts me off going back to them for anything, especially when get them from local motor factors for £36!
Help, please....
Help, please....
It's the door latch switch mechanism, they are pretty cheap and easy to replace. Mine is still under warranty. I knew what it was so, I had the parts guy order me one. When I took it in they had the car back to me in 2 hours. They were surprised to find they had one on the shelf.. Little did they know, I had ordered it before my appointment a few days earlier.
No, they did away with the actuator for the 08-14 CL. It is the entire latch assembly. Once you change that your troubles will go away. It used to be partially pneumatic and electric, now its fully electric. If you go on MBpartsonline.com and look for the latch. I think you can find a new one pretty reasonable and DYI.
