Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CL55 AMG, CL65 AMG, CL63 AMG (W215, W216)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
CL55 AMG, CL65 AMG, CL63 AMG (W215, W216) Discuss the CL55, CL65, and the CL63 AMG.
Sponsored by : Velos Designwerks
Click Here
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-03-2012, 01:19 AM   #1
Drives: Cl65 AMG
IC/mini radiator/new Meziere pump
My plan is to use the fender mounted mini radiator & cooling fan to cool the heat exchangers. I am going to keep the sandwiched heat exchanger and plum the new pump (Meziere 20 gpm) and the mini radiator.I am going to have them run anytime the engine is running. I understand this will reduce my engine cooling but at this point I'll will just see how it effects things. I do have a new radiator (factory AMG) so maybe it will handle things well. Another thought was to use the outside temp sensor to monitor the intake air temp. If it's like most outside sensors it will have its own program which it that case it wont register in real time. Anyway along with that the system will be separated from the main cooling system. I don't expect to lower the air temps just keep them more consistent and for them to cool down quicker. Everything just for reliability.
Hopefully someone will read this and correct me if im heading in the wrong direction.
John St John
To remove this ad, register today or login if you already are registered!
driveability is offline   Reply With Quote
Old 02-03-2012, 02:46 AM   #2
freestylebiker3's Avatar
Drives: w215 cl65
check out one of my threads of my step by step install of the 20gpm pump
freestylebiker3 is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
ic, meziere, mini, pump, radiator
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
