Sign in using an external account
| CL55 AMG, CL65 AMG, CL63 AMG (W215, W216) Discuss the CL55, CL65, and the CL63 AMG.
Sponsored by : Velos Designwerks ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2001 CL55 AMG
2001 CL55 0-60
#2 |
I've found out that the 01 cl600 can achieve 5.3s and the 01 cl55 has the same torque and hp and weighs less, so I'm assuming my cl55 can also achieve 5.3s or better?
#3 |
Drives: E55, Renntech CL600(sold), GL450
It's rated as 5.8 to 60.
#4 |
Drives: E55 2006 / E55 2000 / White Odyssey
Make sense since W210 E55 has the same engine weight less runs 5.4
__________________
Good judgment comes from experience, experience comes from bad judgment. Kleemann ECU tune + Header + CM30 pump + K&N filter + E63 front conversion + SL55 Gun metal wheels |
#5 |
Yeah but the CL600 is rated 5.8s on wiki as well, but articles claimed that it has achieved 5.3s and the CL55 (2001) is basically the same car and (The 2007 SL550 has the same engine but supposedly makes 382HP, and magazines claim to have achieved 0-60 4.9s) My CL55 has only 20 less HP and weighs less (than the 07 SL550), so it's logical that my CL55 can achieve low 5's 0-60
2001 Mercedes CL600 0-60 mph 5.6 (curb weight) 4400lbs Quarter mile 14.2 ( http://www.zeroto60times.com/Mercede...mph-Times.html ) CL 55 AMG (curb weight) 4000lbs (2001) 5.5 L V8 265 kW (360 PS; 355 hp) 530 N·m (391 lb·ft) 5.8 seconds CL 600 (2000) 5.5 L V12 270 kW (367 PS; 362 hp) 530 N·m (391 lb·ft) 5.8 seconds Last edited by mbenzCL55; 04-26-2012 at 11:18 PM. |
#6 | |
Quote:
As you can see by the actual results of drag strip runs is that the SL550 is considerably quicker than the 2001 CL55 and the CL55 runs the times that are published. http://www.dragtimes.com/compare2.ph...ame=Compare%21 |
#7 |
I think 5.8s is a stretch, I don't think the manual mode was tested with that 0-60 time. Manual mode can deduct .5s I highly doubt that SL550 is over a second faster because of a faster transmission, the CL55 shifts almost instantaneously in the manual mode.
#8 |
I just ran a 0-60 and I timed it around 5.3s
#9 |
Drives: 2004 cl500
Interesting, as I would have like to have known what my 02 cl55 would have run. I never took it down the 1/4 but I'm guessing 14.0-14.5
#10 | |
Quote:
#11 | |
Quote:
Yes, that's where the performance stats and dragtimes run puts it at. Last edited by BlownV8; 04-27-2012 at 11:13 AM. |
#12 |
I was basically at a complete stop, and I've read cars at a complete stop achieve a better 0-60 time than from a rolling start, look it up. The needle was clearly at 0 when I gunned it anyways, and the engine wasn't even warmed up, and the roads were wet. I'm sick of your **** BlownV8, its clear that my car can easily achieve sub 5.5s 0-60 times, and I proved it with that video.
#13 | |
Quote:
Why are you so determined to prove whatever you are trying to prove? Go race a SL550 if you think you can hang. Better yet, go to a drag strip and post something that we can certify as accurate. |
#14 |
Drives: V12TT
Correction:
Your CL55 has a M113 5.4L SOHC AMG V8 The SL550 has a M273 5.5L DOHC non-AMG V8 with variable valve timing.
__________________
![]() ![]() ![]() S600 V12TT - S65 cluster, S65 exhaust, Brabus ABC ELM, CL65 gloss black wheels, delimited |
#15 |
Drives: 2004 E55 AMG
My 0-60 is 3.7 secs.
Check sig for video if you don't believe me. I'm looking at a CL65 for my next beast so lurking here a bit.Alex
__________________
Mods 4 Go: Upgraded Eurocharged HE, 180mm ASP Pulley, K&N's, Kleemann ECU Tune, Floor Fab'd LTH & Cat Back Exhaust, Johnson IC Pump, NGK-LFR7AIX Plugs, TTM scoops, EBC Red Stuff brake pads all around. (600tq/500hp @wheels). Mods 4 Show: E63 lip spoiler and AMG aluminum pedals. My 0-160MPH-0 Run - in 1 mile -(Video): http://www.youtube.com/watch?v=wffK2...ature=youtu.be |
| Tags |
| 060, 2001, 2003, 2004, 2007, 55, amg, cl, cl55, faster, make, mbworld, sl550, specs, wiki |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
