Storing CL63 battery issue
2020 Mercedes GLS450, 2021 Porsche 911 Cab
My car has all types of wired electrical gremlins when stored and not used for an extended period of time (i.e 2 months). I have previously replaced the battery ($600) but I'm having this issues with the new battery that is less then a year old. I don't have an option to connect a battery tender. Can I disconnected the battery and how? Should I put the battery on a trickle charger while not in use?
aux/consumer/supply battery location?
The owner's manual recommends that you disconnect the aux/consumer/supply battery if you will be storing the car for an extended period of time.
That said, where the is this battery they speak of located? "The trunk" is a very broad description. MB is a master at hiding the most crucial of parts
Last edited by dimaSG; 06-21-2012 at 07:34 AM. Reason: nm, found it. its in the trunk. you have to remove the panel from the back of the seat. it slides right off.
i believe in the newer mercedes, i think 2005 and up, there are two batteries. one in the engine compartment and the major, big battery in the trunk.
