CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
*-*-*New Years Sale-3000rpm Stall Converters through BI-Performance*-*-*
Old 01-09-2013, 10:00 AM
Former Vendor of MBWorld
BI-Performance's Avatar
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
We will be running this sale through the end of February, and there is limited stock.
These stalls are for the CL55 and CL63 with the 722.6 and 722.9 tranny's. Running an aftermarket stall will gretaly improve your 60ft at the track, and is a ton of fun on the street. These stalls will enable you to load the converter up at the track, and on the street without having the problem of pushing through the brakes at lower rpm with the stock unit.
$990 plus shipping
Specs on the unit are as follows:
-3000 stall converter for street or strip
-11" diameter vs stock 12"
-10 lbs lighter than stock to reduce rotating mass
-triple lock up clutch
-high performance pump and bearings
-all new units and no core charges, so you can keep you stock converter
Old 01-09-2013, 05:55 PM
nidyanazo's Avatar
550HP+ ///AMG CL55 Kompressor, Ducati 916bp, Yamaha R1 WSBK replica
Hell yeah, now that's a great mod. How is the normal (slow speed) street driving?
If it wasn't such a labor intensive mod, what with removing the transmission ... I'd be all over this.
Old 01-10-2013, 08:00 AM
chawkins2001's Avatar
2006 E55 AMG
Normal low speed driving is great!
Old 01-10-2013, 09:55 AM
shardul's Avatar
2003 W211 E55, 2003 W220 S600
removing the trans is easy if you have a lift. A tech at MB charged me 500 to remove and install a trans.
Old 01-15-2013, 08:05 AM
We have several stalls left fellas.
Old 01-25-2013, 10:31 AM
Several left in stock fellas. Our first customer that had his put in last week sees a noticable difference in power to the ground. His E55 is much snappier, were his words.
Old 01-25-2013, 01:35 PM
nidyanazo's Avatar
I bet this mixed with a limited slip differential, numerically larger rear end gear ratio, and some Toyo proxies r888 tires would just be out of this world.
One of these days I'm going to do a combo like that
Old 02-03-2013, 05:37 PM
For the month of February only, discounted to $880 plus ship btw
Old 02-04-2013, 04:31 PM
kelwilliams08's Avatar
CL 55 AMG
i think im ready to pull the trigger on this one...
Old 02-15-2013, 05:48 AM
Friday bump.
Old 03-01-2013, 10:34 AM
Friday bump
Old 03-08-2013, 09:04 AM
Up top
Old 03-17-2013, 11:38 AM
Just a couple weeks left of the sale brothas.
Old 03-18-2013, 10:19 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
This was one of my favorite and best mods for the money. I was like "Damn",,, AMG should have put this verter in from the factory, as this is the way the CL55 should roll. Drives smooth and stock, until you punch it and then all hell breaks loose.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 03-27-2013, 09:41 AM
We have decided to extend the sale through spring
Old 04-23-2013, 09:36 AM
We are still running this sale guys $880 plus ship.
Old 06-25-2016, 03:51 PM
Dr Matt's Avatar
05 CL65
Anyone ever tried one of these in a 65?
Old 09-01-2017, 05:28 AM
Hi-Mi 05CL65's Avatar
2005 CL65
Does this work in 2005 CL65?
Would be interested if so. I see Matt asked, but never received a response.
Roger
Old 11-09-2017, 02:12 PM
Jimrowe0's Avatar
72 corvette, 02 Z06, 06 CLS55
Still have any of these?
Old 11-09-2017, 08:04 PM
2006 E55 AMG
These would fit the CL65 transmission, and sending pm's to those still interested in the stalls.
Quick Reply: *-*-*New Years Sale-3000rpm Stall Converters through BI-Performance*-*-*
