replaced cracked radiator..
Mercedes CL55
I got my radiator replace the other day because it had a crack... I had the leak for a couple weeks hoping it would be a hose or something but when I finally had time to bring it to my mechanic he pointed out that it was a crack. He said it cracked because my car is too low. Is that possible? My car is pretty much slammed and I drive my car daily.
2005 cl65 AMG, 2014 e63s AMG
This is interesting... I recently had my radiator replaced under similar circumstances... It started to leak around the upper radiator hose. Turned out that the end tank was cracked. My car is also *very* low (probably too low to be honest)... I never even considered it to be related to the ride height. Honestly, I can't see how the ride hide could have caused a crack around the upper radiator hose but I suppose anything is possible.
I will be following this thread with interest.
-LeoD
-LeoD
Mercedes CL55
-LeoD
-LeoD
Very interesting... I know my car rides A LOT rougher lowered. It looks cool but I'm not certain it is worth the added risk/cost (see my other thread on tire wear). I'm going to be dumping my "links" and going for a module... The thought of my car lowering even lower than it is at 60+ is down right un-nerving.
Mine is too low to begin with... I can only drive it in the highest setting (on the dash) or I will rub...
I have to say I liked the way the car rode much better at stock height but the 4 finger gap between the tire and fender drove me nuts!
So did you already get your radiator replaced? My Indie said it took him every bit of 7.5 hours to swap out... They had to remove the front clip (at least that's what he said... I don't have photo's to prove it) but that caught me by surprise for sure..
Keep us posted...
BTW) I've had my car for almost two years and other than tires and service this is the only expense... I see so many people posting about outrageous bills I thought I would throw my experience into the mix +1 for CL65!
Keep us posted...
Mercedes CL55
Keep us posted...
Keep us posted...
W215 V12TT Build by Speedriven, W221 S550 4Matic
Got my radiator replaced last week, paid $700 after parts and labor. My mechanic said it took him almost the whole day to replace it too but he only charged me for three hours of labor. He also said he had to remove the front clip. I feel you on the gap between wheels and fenders, I hate it too but I think getting a module would be best. Drive at stock height and slam it when parked.
cracked because car is low... LOL
They all leaked and cracked from the same spot all of my S or CL. Check your motor mounts. Engine lifts up if mounts are bad and the upper rad hose doesn't have that much extension play.
Check your CL fenders I bet there are starting to crack too from the inside where it is bolted, maybe your mechanic is leaning on them too much is what someone will tell you instead of they are a crappy design and they crack on every CL out there
plus one on the fenders. there should be a recall!
Mercedes CL55
PLATINUM SPONSOR
They won`t crack from being to low. No way to hit the rad on the ground and just because it rides rougher, should not cause it to crack. Some cars may be stock height and ride on rough rodes, so they shake just the same. I changed my Rad myself and it is a beeeach to do but bought a new one for 275.00.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
