My "Factory" Split Cooling Tank
MBworld Guru
Since I've removed ABC from my CL55, I decided to use my old fluid reservoir. I used a Dremel and handsaw to separate the ABC reservoir from the power steering tank. Seems that it should hold a fair amount of fluid plus it will self bleed without spraying coolant everywhere
