code and power window inop
05 CL55 AMG
out of no where after battery went dead I now have a b1010-015 code that resets every time-hard fault
I did a battery disconnect over night with no resolve
rh rear power window inop-all fuses good-
code states term k1.30b low or no power---Where is this circuit?
My scanner shows the rh power window switch operating from the rear control but not the master front control and rh rear window is denormalized
all other windows work
05 CL55 AMG
Rear window still inop
sets hard code in rear sam -- B1010-015
Anyone???
05 CL55 AMG
FIXED
The problem turned out to be no power at rear sam for RH rear window only.
code states term k1.30b low or no power---Where is this circuit...
The circuit 30B power comes from the rear (under seat) fuse box.
No power no window op
thanks
hope this helps someone else.
thanks
thanks.
