Intercooler pump comparison test
I have been shopping for a new intercooler pump for my Cl55 since the stock one retired on me yesterday. Luckily I had a new Jabsco replacement IC pump for my GMC Typhoon to install until I sort out what pump is best for my application. During my search I came across a comparison test on another forum. If this is old news then disregard.
http://www.lingenfelter.com/LPEforum...esting-results
Mercedes CL55
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
In the V12 Section, a guy named Welwynnick or something in the line of, made some amazing topics:
It all started here: https://mbworld.org/forums/w211-amg/...now-about.html
Then went here: https://mbworld.org/forums/m275-v12-...ion-pumps.html
i dont remember if there was a 3rd topic though.
I went with the mighty CWA-100 pump by Pierburg.
As for Crissus, yes the topic is old, more than a couple decades old but the information on the link that I posted is far more in depth than the ones you posted in reference to my initial post. The MB is the 3rd liquid IC vehicle I have owned the first being the GMC Typhoon that I still own and the second being a 2nd gen Lightning that I no longer own. It seems that nothing significant has changed with these systems since they were first introduced in production vehicles.
Yes, I added those Lingenfelter test results to the thread in Nov '13 in this post. I added their test results to other pressure/flow curves that I'd from other sources, and combined them here.
This was rather a pain, as Lingenfelter used imperial units, while everyone else use metric. They also used pressure (instead of flow) as the indepenent variable (unlike everyone else on the planet, unfortunately). That made transcribing their results very tedius.
However, the results are invaluable, as they show the difference between installed and open pipe tests. They key findings being that pressure is more important than flow, and the Johnson CM30 and Meziere WP136 really aren't the good choices that people thik they are.
https://mbworld.org/forums/m275-v12-...ml#post5836390
The EMP WP29 really is the daddy though, if you can find a way to control it (which I haven't yet).
Nick
Nick
That's kind of a bummer to see that the Meziere pump I just installed does not really perform that well. I have put up with hight IAT's killing power since I got my car thinking the stock system just sucked since my pump was replaced under warranty less than a year before I bought my car.
Turns out it was probably just because the dealership who worked on my car for the previous owner just sucked. When I removed the stock pump I only lost about a cup of coolant. When I vacuum filled it back up I added about 3 quarts. After installing the Meziere my IAT's are 40-80* cooler than before. Turns out the stock system is not so bad if the pump isnt sitting in a big air pocket.
The stock system is full of air locks, and vacuum filling is the only reliable way to fill it. Even then, I don't think the Mercedes filling rig is adequate, as the vacuum doesn't go low enough to boil the coolant inside. I think you need a proper high vacuum, single stage, vane pump to evacuate properly (like AC service shops use). My alternative was to use an upside-down, back-to-front BMW X3 radiator, use the drain valve for bleeding, and use the fill ports on the charge coolers as bleed ports, in conjunction with the swirl pot.
I don't think you need a big heat exchanger or a big pump to make the IC system work, but you do need a way to get all the air out.
Nick
Nick
Nick
Nick for normal applications is the bosch oem pump adequate for a car that gets driven at the most once a week? I don't want to splice wires and keep things stock
Sure it is - as long as it's working OK (and I bet many of them aren't).
I think making sure the IC cooling system is full and free of air is more important than which pump to use.
Nick
Nick
So has anyone figured out a way to control the EMP WP29 pump in our application? It's obviously a badass pump, but will it work in a w215/216/221 without a Frankenstein re-wiring job?
