Loud engine ticking?
Started the car today and it had a loud ticking, like a lifter problem or something. 2008 CL63 with 70,000 miles. Just had it serviced 6 weeks ago at MB sugarland dealership. Heres a video. What do you guys think?
Shardul,
I have powertrain warranty. I have been going to MB Sugarland, any eason not to deal with them? Any Better ideas? Thanks. BTW, I am in Bay City, so it's probbly gonna be a good size tow charge.
BTW, the car has 70K miles, properly serviced, how can it have valve train issues this early?
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Shardul,
It can be a uncommon failure. Keep us posted on what they find out. My friend has a E63 with 40k miles and he dropped a valve. MBSL put a new engine in the car.
Got the car into MBSL today, but they wont be able to really get a look at it till Monday. Said it sounds like a stuck lifter. Would that cause a drop in power?
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
It might be a long shot but when I had my abc pump replaced and after 3 weeks it was making a ticking sound. I was fearing the worst but had the hood open and tech was looking at the idle pulleys while it ran when he notice a bolt to the abc pump came loose and he torqued it up again. Turned it on and sound went away. Again its a long shot but if you went in for some kind of abc work, it might be a bolt that got loose.
Dealer said they cannot hear the ticking that was in the video I showed him. He said the accumulator sounds bad, not the ABC pump. He quotes $1500 to fix it. Sounds high to me. What do you guys think?
Accumulator is not a 1500$ job, unless they are replacing all 4 of them... and even if they are doing all 4 1500$ is high
1 accumulator is about 150$ part only
is the dealer talking about the hose, or the accumulator cylinder?
He just said accumulator. I picked the car up today. The ticking from the video is gone. And I cannot hear the "howling noise" he talked about either. Car sounds just fine now. Go Figure.
It was probably a collapsed lifter. They can bleed down when an engine sits for a while, then pump back up after the engine develops oil pressure.
i believe the accumulator is also called the pulsation dampner and that is a hose and would probably cost $1500 at the dealer, where as the regular accumulator would probably be a $300-$400 price. it would really be interesting to find out which one there talking about. do you have the part # on your invoice?
2008 cl63 amg/2015 gla250 4matic
It's happened to my car today too guys 08 cl63 with only 52k miles car been have a humming howling sound whatever is it ,and today I started it heard loud ticking sound while driving then I stopped the car turned off and turned it back on and drove away and the sound was gone, then cruise for like 20 miles and the car is acting normal , so worry don't know what's going on
tx Nuke, you have been getting a lot of help on the forum, it would be nice if you reciprocated when someone asks you a question, or asks for a response. i.e. part# on invoice.
thanks
thanks
