W215 CL65 AMG Brakes on W215 CL55
Hi all
Looking at a possible upgrade setup, to the 65 amg brakes on to my 55.
I have the 65 style alloys so fitment inside the wheel should be fine.
It also seems as the fronts will be a straight swap as the front wheel hub and the steering knuckle (with the caliper mount points) are the same parts numbers between the 55 and the 65.
The rears however is where I'm not 100% sure. I know the 65 has different rear hubs, and the parts numbers that are different are:
Rear wheel hubs
Rear wheel carrier (with brake mounting tabs.)
So the question is, are rears likely to be bolt on as well, considering the hub is different, likely to accommodate a larger drive shaft, and the carrier is different to accommodate the larger hub?
Thanks in advance all!
Rear wheel hubs
Also, comparing the rear disc visually and by spec, they are different.
diameter is the same.
Bolt pattern also looks identical.
Disc height on the 65 AMG is 69mm
Disc height on the 55 AMG is 61mm
65 Disc looks like this:
55 Disc looks like this:
It looks like the diameter is the center is larger, based on the imprint left from the wheel.
No, the 65 rear hubs are different, they're not interchangeable, sorry. There's a thread about this:
https://mbworld.org/forums/s55-amg-s...-w220-s65.html
Thanks Nick
I was aware of the difference in rear offset for the wheels, and have had a very detailed look into the suspension differences between the 65 and 55's.
In my opinion, the fronts will fit without modification, The hubs, suspension arm, mounting etc, is all the same. Only the discs and calipers have a different part number.
The rears, as you say, are a bit more complicated.
They have a different Hub, a different rear hub assembly (with caliper mountings) and a different drive shaft part number. It seems as though it has an older 140 hub, and a thicker, shorter drive shaft. Possibly for power reasons.
There are also different part numbers for the handbrake shoes that go inside the hub.
However, despite those differences, I am still confident they will fit, as the difference in rotor height on the rear, is 6mm. This could be taken up with different caliper mounting brackets (that go in between the caliper and the hub mounting.
Also, the hub diameter seems bigger on the 65, but the smaller 55 hub will still fit inside the disc hat.
It will seem trivial to test fit them when they arrive, but I will post my experience as I have purchased them now. I'm hoping the discs are in good condition wear wise.
Using Racing Brakes instead
Consider returning the 65 brakes.
I'm using the Racing Brakes front and rear. The are a huge improvement, e.g., 30% less unsprung weight over the stock iron MB disks and are a bolt on solution.
Using the 65 brakes doesn't give you this advantage and is much more work.
http://www.racingbrakes.com
Former Vendor of MBWorld
We have a package for CL55 (front/rear + pads) here that can save user 10% on rotor and pad than purchase them separately:
http://www.racingbrake.com/ProductDe...Code=MB-IRK-15
Weight saving info:
Front: OE 1pc=36.5 lbs, RB 2 pc=24 lbs. You save 12.5 lbs/rotor
Rear: OE 1pc=21.5 lbs, RB 2 pc=15.2 lbs. You save 6.3 lbs/rotor
Total weight saving on four corners: 37.6 lbs (32.4%, almost 1/3)
A massive weight reduction.
RB rotors are made for user friendly DIY installation - A direct and 100% bolt on OE upgrade/replacement.
Parts are in stock for prompt shipment.
Thanks for the referral, and you are well qualified to testify the benefit of RB light weight two piece rotor replacement from your experience.
Weight saving info:
Weight saving info:
This front rotor (390x36) is for S55/S63/S65, and has the same offset as C63:
http://www.racingbrake.com/Two-piece...ONT-p/2237.htm
This rear rotor (360x26) is for the rear of above, and has the same offset as the rear C63:
http://www.racingbrake.com/Two-piece...-07-p/2227.htm
Complete car rotor kit:
http://www.racingbrake.com/RB-Two-pi.../mb-irk-04.htm
For front you can use the same caliper but will need a longer bracket which can be made available like we proposed for upgrading to the "Black Series" in this thread:
