Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > CL55 AMG, CL65 AMG, CL63 AMG (W215, W216)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
CL55 AMG, CL65 AMG, CL63 AMG (W215, W216) Discuss the CL55, CL65, and the CL63 AMG.
Sponsored by : Velos Designwerks
Click Here
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 09-10-2004, 09:53 AM   #1
BklynBenz's Avatar
Drives: CL500
Send a message via AIM to BklynBenz
CL 55 AMG "F1 Limited Edition"
The CL 55 AMG "F1 Limited Edition" is the world's first roadgoing automobile to be equipped with an ultra-high-performance ceramic braking system.
The engineers at DaimlerChrysler AG and Mercedes-AMG GmbH have developed internally ventilated brake discs made from fiber-reinforced ceramics for this unique high-performance coupe. The use of ceramic brakes in the CL is part of a pilot project with a view to offering this technology as optional equipment for the S and CL 55 AMG models. The model on which this stunning special edition is based is world renowned in the field of Formula 1 as the CL 55 AMG safety car.
In line with the thoughts of twice Formula 1 World Champion Mika Häkkinen - "The most important thing in a sportscar is not the engine, but the brakes" - the ceramic braking system not only ensures ultra-short braking distances but also an extremely sensitive response. Other key properties include a high resistance to heat and continuous stresses, low maintenance and a long operating life. When emergency braking from maximum speed, a braking performance of approx. 2000 hp is generated at the front axle. Another advantage of this technology, which is completely new to series-production cars, is the significantly lower weight of the brake discs. Each disc weighs approximately six kilograms less than its steel equivalent. The noticeable reduction of unsprung masses results in improved dynamics and greater driving enjoyment. With this ceramic brake DaimlerChrysler AG once again asserts its leading position worldwide in the development of ground-breaking automotive technologies. The Mercedes-Benz CL 55 AMG "F1 Limited Edition" with the new high-performance braking system will be produced in a particularly exclusive limited edition of 55.
The new front brake discs of carbon-fiber-reinforced ceramics are approx. 60 percent lighter in weight than comparable brake discs of conventional cast iron. This significantly reduces the unsprung masses, with a noticeable improvement in driving dynamics. By virtue of these lighter brake discs the steering of the CL 55 AMG "F1 Limited Edition" is also more responsive and precise. The significant weight advantage also has a positive effect on suspension comfort. However, these are by no means the only the advantages to be obtained from the high-performance "C-BRAKE", which was first shown in the Mercedes-Benz SLR super-sportscar in 1999. The new material also exhibits a very high temperature stability. The maximum temperature load is up to 1400 degrees Celsius. This provides a level of safety when braking from high speeds which was previously unknown in series-production cars. The extremely low thermal expansion of the ceramic brake also reduces juddering when the brakes are hot. Brake squeal and juddering when cold - two familiar characteristics of cast iron discs - are also considerably reduced with the ceramic brake. The extremely long operating life of up to 300,000 kilometers and the low maintenance also speak for the new, absolutely corrosion-free ceramic brake discs. But it is not only the internally ventilated ceramic brake discs that are responsible for the uniquely sensitive response and very short braking distances of the ceramic brakes of the CL 55 AMG "F1 Limited Edition": eight-piston brake calipers which were specially developed for this fast high-performance coupe by the Formula 1 supplier Brembo reliably ensure the necessary deceleration. The design of these calipers was specifically tailored to the fiber-reinforced brake discs. The anti-lock braking system ABS, Brake Assist and the Electronic Stability Program were also carefully adapted to the new braking system.
During the development of the ceramic braking system the findings on high-performance carbon brakes gained by AMG technicians in touring car and GT motorsport were every bit as important as the results of basic testing carried out by DaimlerChrysler researchers. In the production of ceramic brake discs, carbon fibers, powdered carbon and resin are pressed into shape under high pressure and baked at 1000 degrees Celsius. After cooling, the brake disc is subjected to a brief machining process and treated with liquid silicon. The carbon matrix absorbs the silicon like a sponge and their reaction forms a ceramic. The patented production of these innovative brake discs is carried out according to the strictest quality standards by highly-qualified specialists at the DaimlerChrysler plant in Esslingen-Mettingen near Stuttgart.
The unique character of the Mercedes-Benz CL 55 AMG "F1 Limited Edition" with ceramic brakes is also emphasized by the particularly exclusive equipment and appointments. Equipped with a 5.5-liter, 265 kW/360 hp V8 engine and available only with brilliant silver metallic paintwork, the limited-edition top-class coupe has exquisite AMG styling and presents a very striking appearance. 8.5-inch (front) and 9.5-inch (rear) wide, 19-inch AMG light-alloy wheels with 255/40 ZR 19 tires at the front and 285/35 ZR 19 tires at the rear underline the car's uncompromisingly sporty nature. The reduced offset of the AMG wheels optimizes the track widths, and in conjunction with the widened rear fenders this lends the CL 55 AMG an even more imposing appearance. The high-performance wide-base tires of type "S-02 Pole Position" are supplied by the Japanese McLaren-Mercedes Formula 1 partner Bridgestone. Particularly dynamic handling is also ensured by the sporty configuration of the ABC suspension, which has won several awards. In addition to the "F1 Limited Edition" lettering on the front fenders, the interior of this exclusive Mercedes coupe also features cues from the motor racing activities of Mercedes-Benz. Numerous special characteristics distinguish the CL 55 AMG "F1 Limited Edition", which is available only in brilliant silver metallic, from its series-production counterpart: - "F1 Limited Edition" lettering on the center console, with consecutive numbering - Illuminated entry sills with "F1 Limited Edition" lettering - Front seats of ultra-sporty design with optimum lateral support, black/silver leather upholstery and embroidered AMG logo - AMG sport steering wheel with perforated leather wrap - Carbon decorative trim - Automatic shift lever in leather-carbon combination - Floor mats with AMG logo
To remove this ad, register today or login if you already are registered!
BklynBenz is offline   Reply With Quote
Old 09-11-2004, 09:06 PM   #2
Mr.PS's Avatar
That looks like a pre 2003 F1 edition I really liked the birdeye maple and two tone sport seats in those. Are they making them again now. ?
Mr.PS is offline   Reply With Quote
Old 09-12-2004, 03:28 PM   #3
MadC32's Avatar
Drives: C 32 AMG (203.065)
yeh thats an old one.. really rare though.. were all sold before the were ready to sell
__________________
99 Mercedes-Benz C 43 AMG
08 Mercedes-Benz A 200 Turbo (sold)
03 Mercedes-Benz C32 AMG (sold, and still missing it)
02 Mercedes-Benz C230 Sportscoupe (sold)
96' BMW 325i (sold)
MadC32 is offline   Reply With Quote
Old 09-12-2004, 04:43 PM   #4
Super Moderator
awiner's Avatar
Drives: 2003 CL55 AMG
No, they only made the F1 in 2001. 55 units were made.
__________________
Adam
2003 CL55 V8 Kompressor
Parktronic, v60 Phone, Keyless Go, Trunk Closer, Painted Front Side Lenses
MP Designs Sport Steering Wheel, 19" HRE 847R's, Brabus Lowering Module
Ice>Link Plus iPod Photo 40GB Color Integration into Factory COMAND
2005 MV Agusta F4-1000
2005 Kawasaki ZX-6R (636)
awiner is offline   Reply With Quote
Old 09-12-2004, 09:52 PM   #5
Mr.PS's Avatar
AMG should an us option to have more cars with two tone interior I havent seen any designo AMG's. The silver/black combo is gorgous.
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
2002, 2004, 55, 55s, amg, cl55, cls, edition, f1, foto, front, made, mat, special, view, wete
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Update pics on my AMG Brakes/Brabus Rims & CL Grill instals kepiting C-Class (W203) 50 11-02-2005 11:33 PM
New Mercedes-Benz CLS 55 AMG Unveiled slytoksy CLS55 AMG, CLS63 AMG (C219) 22 09-15-2004 03:41 AM
CL 65 AMG, omg so fast pogotango CL-Class (W215) 3 04-10-2003 05:14 PM
FS: Brand new 19" AMG CL with tires! TCM GLX Wheels, Tires, Suspension & Brakes Forum-Sponsored By Tire Rack 0 03-23-2002 01:13 PM
Looking for the price and AVA on these new CL 2pc 18" AMG Wheels for the CLK?? RezaH CLK-Class (W208) 3 02-07-2002 10:47 PM
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
