Sign in using an external account
| CL55 AMG, CL65 AMG, CL63 AMG (W215, W216) Discuss the CL55, CL65, and the CL63 AMG.
Sponsored by : Velos Designwerks ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
__________________
Jonathan jmeyersnv@yahoo.com _________________ 2007 CLS63 (Designo Mystic White package) -- on order 2006 CLS55 (Iridium Silver w/ash seats) -- now driving 2002 Lexus SC430 (Egyptian Sand Pearl w/ecru seats) |
#2 |
Drives: 2001 CL500
sounds like you had an awesome time
get the 65!!! |
#3 | |
What gets me too is, if you spend 180K on a car, I wish they could unleash its full potential. I know the transmission can't handle it, but can you even image what that would be like? I also have an E55, and I am dreaming of getting an E65, if that ever comes out, or a CLS65. I haven't driven any of the 65s but, if I know what 516lbs feel like, just image 730 lbs. Or like I said before, 800+ lbs since that is what that engine is capable of.
I wonder if they could retrofit a transmission later on to handle to true power of the engine? amgB Quote:
__________________
AMGB Last edited by AMGB; 11-13-2004 at 01:35 AM. |
#4 |
Drives: SLK55 AMG
I just wish if they could unleash the full potential power of the car ... paying 180k for and restricted isn't fair enough.. although its damn so much fun even at lower speed.
#5 |
IMO the 65 is purely for status, being the flahship and stuff, the 55s should do the job for most including me
#6 |
Super Moderator
Werd...get the 55 and from the money you save mod that and it'll be that much quicker
__________________
4 door sedan with a couple "go fast" mods, some wheels and air-matic delete... A little faster than stock... :D |
#7 |
I've driven all four, the 55, the 600, the 65, and the Renntech 600 Stage III. The 65 and the 600 StageIII are about the same as far as I could tell (612 vs 635 hp, not much difference).
There's a huge difference from the blown V8s to the BiuTurbo 12s, but for the $180K (actually the dealer was asking 225K! for the 65), consider that you can probably pick up an '03 CL600 Sport for $90K and spend $6 on the Renntech upgrade. That's about HALF the price for virtually indisinguishable to all but other AMG enthusiasts. It also leaves you $90,000 to spend on strippers and ****tail waitresses, if you're into that sort of thing. Hey, when I previewed this message, it turns out you can't say ****tail! I'll bet you can't discuss your collection of Bruce ****burn albums eithers!
__________________
Dave 2003 CL 600 Sport 638hp, 765 ft/lbs |
#8 |
Drives: 2006 CLS55-030, 2002 BMW 540 Wagon, 1995 VW Jetta GLX
Just came back from driving the CL65 and I must say I was disappointed. To me it did not feel any stronger than the SL55 that I have driven and ridden in many times. It seems that the limiting factor here is the rear tires ability to transfer the power to the road. The CL65 motor is being dialed back constantly by the traction control system, consequently the full potential of the motor is not taken advantage of. Now, if the CL65 was 4-Wheel Drive all 738 lb. ft. of Torque could be used. Some other things I noticed was the higher stall speed Torque Converter which made it necessary to use noticeably more throttle position when just putting around town and this added to the off idle laziness and the lack of squirtyness (my terminology) compared to the SL55. What the SL55 does at 1/4 throttle instantly the CL65 takes 1/2 throttle and you have to wait for all it's systems to get wound up to go. This squirtyness of the 55 motor is what makes it a better choice for the streets of the USA. That instant gratification when you want to dart around a corner or accelerate around another car and it only takes a little throttle to do, as opposed to having to mash the throttle to the floor and still wait that little bit. Now put the CL 65 on the high-speed roads of anywhere else and I am sure it will be the monster it is said to be and the 65 motor is an awesome piece, MB just has it hooked up to the wrong drive train. Sorry for the negative report but that’s how I feel and especially if you are going to spend another $80,000+ you would think this thing would slam you into the seat and never stop, Not So! It all comes down to those two patches of rubber at the rear and how much Torque and HP that can be poured thru them.
- Bob
#9 | |
Thanks for the info. I have been thinking about picking up a CLS65(if it comes out), or one of the 65, but, I don't know if I can justify the cost. Knowing that it has that much traction problems, the SL600 with a slight mods would give you the same as the SL65. I wonder if MB can fix this problem in the future. The 65 series really makes me amazed, so I hope there is some tuner that can figure out a way to put the power to the pavement.
Quote:
__________________
AMGB |
#10 |
Drives: Mercedes-Benz A170 CDI
The SL65 is the best 65 car because not only is it the fastest, it also possesses an LSD, 0-60 in 4 flat or slightly less (3.9) have been measured....
__________________
#11 | |
Drives: '13 MB SL550, '12 BMW 750Li xDrive
Quote:
), but these engines truly shine on the autobahn anywhere from 100-190mph. As far as I know, there has been virtually no 65 delivered in Germany without the additional de-restriction. After all, if Mercedes was after pure 0-60 times, all they need to do is to upgrade/supercharge a C55 and easily beat a 3.9 time. But if you want the V12, then davepl has it right, get a slighty used 600 and upgrade it. Especially as these cars are almost at the end of their model life. Personally, a 4 wheel drive AMG-SL or CL makes a whole lot more sense than more torque or horsepower. This way I get all that power on the road... Wolfman |
#12 |
Drives: many
Benz doesn't have LSD. They all have open diff.
The limiting factor is the trans. It was never designed to handle torque of 600. So with 65 - let's see when first cars will come back to dealer with blown drivetrain parts. I know that early SL55 had problems with clutch packs. |
#13 | |
Super Moderator
Drives: 2003 CL55 AMG
Quote:
Where have you read/substantiated this ? I have not been able to find anything yet to verify this.
__________________
Adam 2003 CL55 Parktronic, v60 Phone, Keyless Go, Trunk Closer, Painted Front Side Lenses MP Designs Sport Steering Wheel, 19" HRE 847R's, Brabus Lowering Module Ice>Link Plus iPod Photo 40GB Color Integration into Factory COMAND 2005 MV Agusta F4-1000 2005 Kawasaki ZX-6R (636) |
#14 |
Drives: 01 E55 AMG
I've been AMG shopping lately and I drove a 2004 CL55 with the Renntech 600hp upgrade and it was silly fast. Forget about flooring it at anything less than 50mph because the ESP kicks in big time. It felt like with ESP off it would light the tires up is floored at 50mph.
I drove a 2004 E55 last Friday and for me this seems about right for the US. Seat of the pants it feels much quicker than my '01 E55. Realistically even the E55 is overkill but I sure liked the w211. The most the dealer would give me on trade was $33k! Oh, he took 3k of MSRP for the '04 with 6k miles on it. I guess I'll be hanging onto my '01 for (quite) awhile longer. |
#15 |
http://www.amg-owners-club.org/board...=&hilight=sl65
"In the SL 65 AMG power is transmitted by the AMG SPEEDSHIFT 5-speed automatic transmission with steering-wheel gearshift controls and manual mode. In keeping with the tremendous levels of power and torque available, a number of measures have been taken to optimise key transmission components – including the adoption of newly developed clutch pack discs and modified shift and torque-converter-lockup logic. There are also special drive shafts, larger hub carriers and wheel bearings and special spring links at the rear axle. In the reinforced rear axle differential case, fitted with a heat sink, is a mechanical, asymmetric, multiple-disc limited-slip differential with a lock factor of 40 percent under load. This ensures good traction, particularly with a very sporty driving style. With the modified acceleration skid control system, which is equipped with traction logic, the high engine output can always be optimally transmitted to the road." http://www.einszweidrei.de/mercedes/sl65amg2004-1.htm Test in ams 13/2004 Gewicht 2057 kg 0 - 80 km/h 3,0 s 0 - 100 km/h 3,9 s 0 - 120 km/h 5,1 s 0 - 130 km/h 5,9 s 0 - 140 km/h 6,6 s 0 - 160 km/h 8,2 s 0 - 180 km/h 10,1 s 0 - 200 km/h 12,6 s
__________________
#16 |
Super Moderator
According to everything else I have ever read this appears to not be the case. Wonder if this was an early DCAG release that may have changed.
Car and driver recently tested the SL65 in their magazine and commented that compared to the SL600, the traction was terrible with the increased power of the 65.
__________________
#17 |
Adam, if AMS can get that sucker to do 62.5mph in 3.9, so 0-60 is probably 3.8, don't you think the LSD was helping>?
CD should not be trusted at all, they think "stock" Sl600's do 60 in 3.6 and F430's in 3.5 No-one ever said deploying 1000Nm was ever going to be easy.....
__________________
#18 |
Drives: W215 CL600
AMG is now making LSD's for cars which will be covered under the warranty. You can all contact Harris for more information. Seems like a "must have" if you really want to get all the power from the ///AMG's.
I have to buy wheels/tires first before I start modding this puppy!
__________________
2003 CL 600 : - Speedriven ECU - Speedriven TCU - CM30 Intercooler Pump Upgrade - 18" AMG Stockers (Chicago roads suck) - Lorinser Side Skirts - Lowered via Lowering Links - Rear Lip Spoiler - Bluetooth - V12 Biturbo Side Emblems - Painted Side Markers, Grille - 35% Tint - K40 Radar w/ Laser Jammer Gone but not forgotten: 99 CLK320, 98 ML320, 03 CLK320, 04 C32 AMG, 03 E55 AMG, 07 CLK550. |
#19 |
Super Moderator
Who knows Bilal.... Most magazines are totally full of crap in the first place. I just wish MBUSA or DCAG would post specs more clearly. Other than the quote you posted, no one has ever verified the claim and some at MBUSA tell me there is no LSD on production models straight out of the factory; Only after production.
__________________
| Tags |
| 060, cl65 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Test Drove 350 today | ElDiabloJoe | SLK-Class (R171) | 11 | 09-29-2004 02:28 PM |
| Drove a CL600 today at RusnaK Arcadia | VAHAGN MB | CL-Class (W215) | 3 | 07-20-2004 03:31 PM |
| Went to look at a CL 55 today.... | glowrider | CL55 AMG, CL65 AMG, CL63 AMG (W215, W216) | 7 | 03-10-2003 11:55 PM |
| Drove a E500 today. | AutoSaurus | E-Class (W211) | 1 | 08-31-2002 06:12 PM |
| Test drove the new 1.8L today... | Iceman's C230 | C-Class (W203) | 21 | 08-02-2002 08:33 PM |
