CLA Coupe (C117) 2014-present
2014 CLA250 spacer
Old 04-05-2016, 01:29 PM
dCLA503's Avatar
2014 CLA250
2014 CLA250 spacer
Looking to add spacers to my 2014 CLA250. Currently have 18' AMG wheel riding stock height. Looking for any advices/suggestions on the size of spacer for more aggressive look. thank you!
Old 04-14-2016, 07:02 PM
iamracerX's Avatar
cla45
wheel spacers
I used 12mm in rear and 10mm in front. its pretty much as wide as you can get without rubbing. it took me a while to get the right fit. John
btw, make sure they are hub centric spacers
Old 04-14-2016, 07:06 PM
iamracerX's Avatar
cla45
also, make sure to get the correct size bolts to correct for size difference. ebay sells them
Old 04-14-2016, 09:23 PM
dCLA503's Avatar
2014 CLA250
Thanks! 1. Would you happen to have any pics to share? 2. Do you know what size bolts I should be searching for? Thanks for the input! Greatly appriciated !
Old 04-19-2016, 10:32 AM
dCLA503's Avatar
2014 CLA250
do you know what size those bolts are?
Old 07-13-2016, 04:31 AM
dCLA503's Avatar
2014 CLA250
Vibration at 60-70 mph
Hi. I have installed spacers - 10mm in front and 15mm in back. Notices that at 60 and more mph, I get shaking at the front. Not so sure about the back. Anything I can do to prevent the shaking? I had new tires put on as well, same size as oem and had them balanced too.
Quick Reply: 2014 CLA250 spacer
