Using the heat controls
Probably a dumb question, but what is the official way to turn on the heat in the 2014 CLA 250? In the manual, nowhere does it describe how to turn on the heat. Does the AUTO function work for heat temperatures? From my experience, if I crank the heat up to 78 degrees and have the AUTO function enabled, it doesn't go up to 78. The heat only works if A/C and AUTO are off and I have the fan turned up. Is this correct?
Yep and what temps have you selected in the control module----if you have it set for 72 and it's 77 outside wada you think the control module is going to do,conversely if it's 50 outside wada you think will happen!!
