Rebellion Automotive Product Updates
Former Vendor of MBWorld
1 Post
E63 AMG
Hi All,
We are always keen to push the boundaries and bring new products to customers on the 45AMG platform and this has lead us to our extensive product line.
We have put together a quick run through of our products we offer for those that may have missed them or joined after our initial posts.
Front mount charge cooler radiator - £299 ($459 Approx)
This product was designed and built as a result of customers in hotter locations noticing a significant drop off in performance. This allows an additional 1l of coolant in the system and gives you additional surface area to help keep temperatures consistent.
The kit comes with everything you need to mount the cooler and join into the existing pipework, no cutting is required.
Front mount gearbox cooler
This product was designed and built as a result of customers in hotter locations running into error codes to do with the gearbox, being unable to get into reverse or getting limp mode. This is all due to gearbox oil temperatures getting too high. This allows an additional 1l of Gearbox oil in the system and gives you additional surface area to help keep temperatures consistent. Initial tests showed drops of 20c (68f) during extreme testing.
The Kit includes Stainless Steel Front Mount Oil Cooler, Machined Gearbox Take Off Plate, Pipework and Bolts, Hose Connectors and Mounting Brackets.
Intake - £199 ($299 Approx)
Hand Made in the United Kingdom with a 4 inch inlet and Race derived filter. The filter is fully washable and does not need oiling.
Downpipe - £675 ($999 Approx)
Hand Made in the United Kingdom from 87.5mm Stainless steel the downpipe is perfectly designed to aid earlier Turbo spool and reduce back pressure, Due to the size engine bay temperatures are reduced too.
45AMG 360MM 6 PISTON FRONT BRAKE UPGRADE - £1899 ($2899 Approx)
Consisting of a Lightweight 360mm Brake disc, Forged 6 Piston Calipers, Sports pads and Stainless Steel Braided brake lines it reduces unsprung mass by 18Kgs (40 lbs) while providing significantly better braking capability and feel.
Any questions Please don't hesitate to ask!
To see the rest of our catalogue head over to - http://store.rebellionautomotive.co.uk/
1 Post
E63 AMG
Apologies its on the link at the bottom:
Water Meth kit - £459 ($699 Approx)
This kit is designed for the 45 AMG (Other kits are available), looking to Decrease DET & intake charge temperatures yet maintain or Increase BHP figures. These kits have been proven time and time again in street, race and drag applications. The kit contains all the components needed yet provides a simple and straight forward installation that doesn’t require you to be a mastermind mechanic or tuner to fit.
Kit Contains:
300psi pump with EPDM seals
Allen key can be used to adjust water pump pressure
Adjustable pressure switch [20-120psi markings on switch]
15' of High Pressure Black Tubing
Injector (please supply engine cc & max boost + rpm so we can supply appropriate sizes).
Nozzle Holder
Heavy duty Nickel plated Check Valve
filtered self sealing tank tap
All fittings needed for installation
Inline Fuse Holder with 10 amp fuse
30 Amp Relay which includes the Harness
10' of red and black wire
Zip ties and wire splices and connectors
Alcohol/water injection install Instructions with stickers.
2.25 Gallon Race Tank
Low Level Indicator
Kit Contains:
Nozzle Holder
Low Level Indicator
This may seem like a silly question given how awesome all these products are but... What I want to know is... Is the Rebellion logo on the engine cover just a watermark on the picture or an actual badge that can be purchased? Don't judge me lol
1 Post
E63 AMG
Haha yes they are stickers, we can send some out to you if you like ?
Drop me an email matt@rebellionautomotive.co.uk
Very cool. email sent
Doing my first track event this weekend. Looking forward to seeing how well the car behaves and what kind of numbers it puts down at the strip with your tune.
