A-Class (W168, W169) A140, A160, A160 CDI, A170 CDI, A190, A210 Evo, A180
W169 Error Codes
Old 09-21-2014, 09:57 AM
kkdigger1's Avatar
Mercedes A170
W169 Error Codes
Hello Guys
I am new to the forum. I have an A170 and got the following error codes:
2732 Hydraulic brake reverse gear impermissible opening
0841 Implausible in comparison with the specific pressure in transition
2723 Hydraulic brake reverse gear impermissible opening
0894 Steel thrust belt slipping
I change the Oil and Oil Filter in the gearbox but nothing changed.
There was no Temperature sensor on the car and was showing -38 (If that could of effect anything)
Old 01-15-2016, 12:17 PM
dargassi's Avatar
Mercedes A180 CDI 2005
Hi kkdigger1
I got exactly the same codes when my 2005 A180 CDI CVT went in after losing all gears and going into limp home mode
What did you do to rectify it?
I think it may be caused by ECU as well as oil
I know it' some time ago but hope you can reply asap
Cheers
Quick Reply: W169 Error Codes
