Transmission Oil Change
Old 07-13-2005, 05:13 PM
slvrstar's Avatar
clk
Unhappy Transmission Oil Change
Just took my car to the dealer inquiring about a transmission oil change. They told me it costs approximately $500. WTF. Anyone else gotten their tranny oil changed. How much. Any referrals in L.A. area?
Old 07-13-2005, 06:41 PM
CurYousGee's Avatar
2000 CLK 430
wow....i would like to know too for future reference.....how often do you change the oil anyways??
Old 07-15-2005, 06:32 PM
wnycec's Avatar
2000 CLK 430
in other threads, I have read every 30k... and i have also heard that the MB people say every 100k... if you search thru the threads, you'll see a number of stories about people with tranny problems thanx to their lack or attention to the transmission oil. I just passed 50k and i made sure i got my transmission oiled changed... i'll be doin it again at 70k... but only cause i know a MB tech and he does it for a $150...
Old 07-16-2005, 12:05 AM
Almost a Member!
roger's 2937's Avatar
Just had my trans.('99 CLK 430) flushed/filled with the M-B trans. fluid at approx. 53k miles and it was done at a local auto repair shop. It took less than an hour and when they started the flush, the fluid was "black". When the flush was completed, the fluid was nice and red. Since there is no dip stick to check the level, I purchasecd one from Auto Parts Warehouse and provided it to the shop. The cost was about $250 for material and labor.
Old 07-16-2005, 12:16 AM
patrick39's Avatar
01' CLK 320
I guess it is not cheap because even a local shop charged $250 and dealer usual charges double of ind. local shop.
The menu nor the service booklet mention the interval for trans. fluid change, so I guess I will do it every 5 years or 60000 miles. Will that be too long? My CLK 320 is 4 years old with only 24000 miles.
Old 07-16-2005, 10:41 PM
Almost a Member!
Talking
Patrick 39-I'd change it at 30k, but then I'm a maintenance nut!
Old 07-17-2005, 04:45 AM
CARLSS0N's Avatar
w208
Every 30,000 miles your will need to flush your transmission and the filter
you will need about 16 quart of MB ATF, oil pan gasket, drain plug seal, and a oil filter. It is better to flush it than just changing it because flushing it could get all the dirt out from the transmission
Old 07-17-2005, 12:51 PM
Almost a Member!
BLACK2001CLK's Avatar
2001 CLK 430
Can anyone recommend a shop or machanic that can do this in So. Bay Area?
Old 07-17-2005, 01:06 PM
Almost a Member!
Carlson's right-we used 15 qts. to get a good flush, but with a good flush there is no reason to change the filter.
Old 07-17-2005, 04:02 PM
CARLSS0N's Avatar
w208
But dirt will be stuck inside the filter right ??
Old 07-17-2005, 04:49 PM
Almost a Member!
The dirt has been flushed out, that's why it takes 15-16 qts. The trans. holds 9.5 qts. I believe on a 430.
Old 07-18-2005, 02:53 AM
slvrstar's Avatar
clk
This is what I found out from a mb tech that works inside the dealership. Seriously, engine oils changes are not normal at 10,000 miles and tranny oil changes are not made for 100,000 miles, neither are platinum spark plug changes at 100,000 miles. False advertisement. You can do it , but your car will suffer lots of repercussions from this abuse. Hense, engine problems, tranny problems, loss of power, etc. It's good for dealer though, since it means less money for service package, when you've got problems in the future, they can make money off your service, or better yet trade up. Crooks! Stealerships! But one should get their tranny oil service at no approximately 50,000 miles and engine oil changed no longer than 5000 miles. Also, if you don't drive your car often, with only 24000 miles, just like my car, the 4 years will require you to change your oils also according to the tech if you don't want problems stemming from lack of oil changes.
Old 07-18-2005, 02:55 AM
slvrstar's Avatar
clk
Anyone know of a good place in the L.A. area? price?
Rate This Thread
Rate This Thread:
Quick Reply: Transmission Oil Change
