Sign in using an external account
| CLK-Class (W208) 1998-2002: CLK 200, CLK 230K, CLK 320, CLK 430 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread |
Rating:
Display Modes |
#151 | |||
Park light
#152 | |
Drives: 2001 CLK430 Cabriolet
Quote:
But the issue isn't the light itself being blown or not working, i tested it on the passenger side parking light and it works fine. But i think i may have blown the fuse attached to the wiring harness that the light plugs into on the driver side. Is this something that can happen? and can i fix this? Last edited by Stumbling Corgi; 09-30-2011 at 01:42 AM. |
#153 |
Drives: '99 CLK 320 Cabriolet
#154 |
Drives: 2002 CLK430
LCA removal
Is there a write up for removing the lower control arms. I ordered some polyurethane bushings and I would like to remove the arms and bring them to a shop to get the bushings in. Any help appreciated
#155 |
Drives: MB CLK 320 2001
Fuel level not correct for MB CLK 320 2001
Hello All, I am glad that we have this kind of Questions and fast asnwer from MBWorld. My proplem that my fuel tank is full but the level front of the driver side is not reading it, its going up and down and once i start the car it showe its empty completly could you please advice me what I have to do, some adivce me that the fuel level sensor, I can not find it and I dont know if its the problem from it. could you please give me what I have to do my car is MB CLK 320 model 2001 by the way my car is for GCC waiting your reply soon
#156 |
time digital some of them burned
i have a small problem in the time digital some lights not working could you please tell me how to repair it
#157 | |
Drives: 02 CLK 55 AMG Cabrio, 07 ML63 AMG
What do you mean by "GCC"?
Quote:
#158 |
GCC is the Gulf Cooperation Council Countries
#159 |
I live in Saudi Arabia But Originally from Jordan
#160 |
Drives: CLK320 1999
I hope this can help you
PAL |
#161 |
Drives: C63 AMG , C55 AMG
Twin Ther Not Working
Hi all . I have a 1999 CLK 230 Kompressor which has been a great car up until now . The car gets hot in traffic ( idle) and the twin fans on the front where the black plastic grill is are not engadging at all . My AC works fine and all settings on my climate control seem fine . Also the clutch fan on the engine seems to be spinning quite loose? As in it looks like i could stop it with my hand sort of like its slipping ? Even when warm the fan doesnt seem to be spinning strong and tight . Has anyone had this problem ? Can someone help me .
#162 |
Fuel gauge level
When you fill up with petrol ensure the ignition switch key is removed. Also ensure you use a good quality high octane fuel. These cars work in strange ways.
#163 |
Drives: E63 Designo, SL65, SL 55 030, ML, bunch of old ones
Rear seat removal ,cabriolet..
Mainly I just want to get the seat bottom out for cleaning/treating...thanks
#164 |
Drives: 2001 CLK55
Replace Exhaust Manifolds/Install Short-Tube Headers
I did this on my w208 clk55; it may be slightly different on the 320, but I believe it's identical on the 430.
You'll need: - new headers/manifolds - 8 exhaust manifold gaskets - some extra 6mm studs and nuts - rust penetrating spray - various tools (10mm socket, 10mm box wrench, 13mm socket, swivel bit, long extension, tools to remove coil packs and plug wires) Instructions: - jack up the car as high as possible - disconnect battery - remove 2 nuts securing the brake fluid reservoir, and move aside - remove 1 plastic nut securing washer fluid reservoir. Remove two hoses on top, and two wires (one on top and one towards the bottom on the front). Move aside (no need to drain fluid from either tank) - remove air cleaner assembly, spark plug wires, and coil packs. Cover MAF with rag - liberally coat all 16 exhaust manifold nuts and 4 catalytic converter bolts with rust penetrating spray, and allow to soak - remove 4 catalytic converter bolts (13mm) from under car - remove 16 manifold nuts (10mm). It may be too tight to get a socket on some, so you may need to use something else (I used a box wrench) - remove manifolds and old gaskets - install new gaskets and manifolds/headers and loosely thread nuts onto studs (if any of the studs came out of the head, they must be threaded back in before putting the nut on) - tighten nuts to 20Nm (I couldn't fit my torque wrench so I just went pretty snug). IMPORTANT: Start at the rear and work forward to ensure proper seal - bolt cats to new headers/manifolds using the same 13mm bolts - replace everything you removed (coil packs + plug wires, 2 fluid reservoirs, and air cleaner assembly) - lower car and reconnect battery
__________________
Member #77 - AMG Orphans Club™ International Last edited by njgilligan; 02-20-2012 at 12:19 PM. |
#165 |
Drives: clk 230 w208
Does any one have instructions on opening the dash of a clk w208, id like to replace a faulty temp sensor display.
#166 |
As far as i am aware i believe the cluster pops out i tried this at a local wrecking yard
#167 |
Drives: 2001 CLK55
I know there's a post on here about it with more detail and pictures...
There are two tabs on the cluster, one on the left, and one on the right. Get two credit cards or something similar and slide them between the dash and instrument cluster on the sides. You have to get between the tabs and the dash. Then just pull out with your hands on the side of the cluster.
__________________
Member #77 - AMG Orphans Club™ International |
#168 |
Thanks guys I will have a look over the weekend!
#169 | |
Display cluster clk203 w208
Quote:
Yep found the post I need to buy some tools. I've attatched the pdf. Hopefully the dispay will arrive this week. Loving this car......................... |
#170 |
Drives: 1998 CLK 320 Coupe
CLK 320 Windows
does anyone know a fix for my problem the windows on my coupe do not drop when you close the doors leaving the top of the glass outside of the rubber. Thanks
#171 |
Drives: 1998 clk320
door stops
Does anyone have pictures of door stop on drivers side of 1998 clk320. and instructions on how to replace and where I can get the stops and how hard it is to replace? Pictures would be great also!
Also, when you adjust your windows(specifically drivers side) down do you turn the screw clockwise or counterclockwise. Thanks, all help is much appreciated!
#172 |
Drives: 2001 Clk 55 AMG
#173 |
Drives: CLK320 1999
From the Daimler WIS
This is what I have for you
PAL |
#174 |
Drives: 1999 CLK 230K
Can anyone on the forum HELP me resolve this please...i drive a 1999 CLK Cab and when i hit a pot hole or the road surface gets really rough and uneven. or i go over a speed bump too fast..ALL 4 windows roll down at the sametime and the convertible light flashes...Using the A/C is now pointless...Has anyone ever experienced this?
#175 |
Drives: 2002 CLK 430
how to remove long wood trim top of dash ?
how to remove long wood trim top of dash ? we have total (w208) of 9 piece
wood trims, i wanna cover it with CF plz any help
__________________
| Tags |
| buttons, cabin, cabrio, change, clk, console, cover, engine, filter, headrest, line, mercedes, pop, snapped, w208 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| w208 brake calipers/rotors | ctrider | CLK55 AMG, CLK63 AMG (W208, W209) | 15 | 10-12-2010 02:12 AM |
| can you put h&r sport springs for w208 clk55 on w208 clk430? need help asap! | kaps | CLK55 AMG, CLK63 AMG (W208, W209) | 1 | 07-28-2005 03:00 PM |
| can you put h&r sport springs for w208 clk55 on w208 clk430? need help asap! | kaps | Wheels, Tires, Suspension & Brakes Forum-Sponsored By Tire Rack | 1 | 07-28-2005 10:04 AM |
| can you put h&r sport springs for w208 clk55 on w208 clk430? need help asap! | kaps | CLK55 AMG, CLK63 AMG (W208, W209) | 0 | 07-27-2005 04:47 PM |
| Projector Xenons for the w208? | ctrider | CLK-Class (W208) | 1 | 02-23-2005 02:34 AM |
