Jump starting a CLK320
Old 12-18-2006, 08:30 PM
Serndipity's Avatar
2001 CLK320 Cabrio
The other day I left my parking lights on overnight and found a dead car in the morning.
Was able to use the mechanical key to open the trunk and get to the battery in the trunk to jump start.
Was wondering if there is a terminal (if so where) in the engine compartment for jump starting?
Old 12-18-2006, 11:53 PM
midget fidger's Avatar
E550 Coupe
I've seen the mechanic do something along those lines from under the hood, but I'm not too sure.
Old 12-19-2006, 12:10 AM
MarcusF's Avatar
2002 CLK430
Ignore the numbers in this picture. The red arrow on the upper right points to a black cover with an X on it. Underneath that cover is a wire that's always hot. You can use just about anything else as a ground.
Old 12-19-2006, 09:04 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Many thanks MarcusF.
I thought there might be one.
My BMW had such a terminal which was covered in the owner's manual as an appropriate way to jump start a weak battery condition.
Old 04-07-2014, 04:28 PM
MsPauly's Avatar
2003 clk 320
FINALLY!!! I found what seems to correspond to my 2003 clk 320 correctly. Does anyone know if I can attach a battery charger to the post shown in the picture?
I just need to charge the battery a little bit to pop the trunk open. THEN I can put the charger on the battery properly.
Old 04-07-2014, 05:30 PM
MagmaRed55's Avatar
Magma Red W208 55 AMG, W203 C230 Kompressor Sedan 6speed M/T, W220 S500
Can you pop the trunk using the mechanical key?
Old 04-10-2014, 02:18 PM
MsPauly's Avatar
2003 clk 320
so here's the latest:
I FINALLY got power to the vehicle by following the diagram MarcusF posted. BUT I had to use ground all the way on the other side of the engine compartment for it to finally work!
STILL can't get the key to work in the trunk lock but at least I could get at the battery now to charge it!
Old 03-02-2015, 09:38 AM
benzrookiegirl's Avatar
Clk320
Can someone help pls! I have an 04 clk 320 just went this morning to start it and key doesn't turn, the steering wheel is not locked, the locks, lights nothing works seems like battery is dead. how do I properly give it a jump? I read the manual but am confused as to if I put the cables directly on the battery to another car or do I use the positive terminal next to the battery and on to my own battery itself? I appreciate any response. thanks
Old 03-02-2015, 09:48 AM
MagmaRed55's Avatar
Although I'm unfamiliar with w209s I would say that you want to jump it with another car. Battery to battery. Or battery to jumping posts, whatever is easier.
Old 03-02-2015, 09:51 AM
Clk320
Thank you Magma Red. so the standard way would be fine...car battery to car battery. I will give it a try just don't want to screw up anything else. Thanks
Old 03-02-2015, 09:55 AM
MagmaRed55's Avatar
I would attach the standard way. Just as a precaution, leave the key out of the ignition during the connecting process. Hook the jumper cables up and see if power is restored to the dash and other interior components, then try to start. Good luck!
Old 03-02-2015, 10:03 AM
Clk320
thanks! just tried to get into my trunk where my jumper cables are but unable to open it...great! guess i'll have learn patience and wait to get other cables thanks for your help. i'll repost when I've got it.
Old 03-11-2015, 08:25 AM
MagmaRed55's Avatar
I'm curious to know how you made out last week, Rookie. Let us know if you need help with anything else, and welcome to the forums.
Old 05-24-2015, 02:14 PM
johnaresch's Avatar
2007 C280 4matic, 2000 Clk320
Thanks for the post. It worked well. But a hint for all the road warriors that are not aware of the battery location in a w208. It is in the trunk and if you can't get the trunk open with mechanical key then all you have is a 3500 pound paper weight. Jumping post to post as the one person suggested is extremely hard when you CAN"T GET TRUNK OPEN. Ugh.
Again thanks for the person with the P6 suggestion (label on black box) it is the hot line to the battery and it does allow an engine compartment jump to another battery. HOWEVER you will need to clear the ABS an BAS malfunctions and re-enter the radio code. Small price to pay to get car running. And for those who will ask, no the BAS and ABS were not malfunctioning before battery failed so completely. And when cleared they do not show a malfunction.
Quick Reply: Jump starting a CLK320
