Power seat ECU repair info
If your power seats crap out on you, the part that fails inside is BTS409L1
SWITCH SMART HIGH SIDE SWITCH.
This is what controls the input on the ecu telling it what to do. The relays are generally never at fault. This switch handles the grunt and grind of everything coming into the unit and therefore can tend to fail after a few years.
You can see the PDF for this part here: http://www.datasheetcatalog.com/data...BTS409L1.shtml
You can see the burnt leg and tracers around the unit. Once you replace this and verify the tracers are back in order, your seat ecu should function well.
Any more info on how to do this and where its located exactly. I'm about to start the project on fixing both Driver and Passenger seats. Want all the info I can get ahead of time.
Is the BTS409L1 is inside the Power Seat Control Module?
P/N: 2088200526 Power Seat Control Module
http://cgi.ebay.com/ebaymotors/Merce...QQcmdZViewItem
My passenger seat control "Back & Forward" moves the seat only Forward, all other functions work. The programmed memory buttons moves the seat backward or forward as programmed. So I know it is not a problem with the motor and believe it is a problem with the Control Module.
Any suggestions?
Any suggestions?
CLK 430
so would this cause the seat not to pull forward when you lift the lever? Cuz when someone gets into the back through the driver side the lever will go up but the seat wont budge.
The Jury I know this might sound like a dumb question but where can I go to buy this little piece BTS409L1. I guess if I buy 2 of them, and remove the ecu from under both seats, unsolder the part and resolder the new BTS409L1 then they should start working again, but where do I go to buy these little BTS409L1? Some kind of electronic store, RadioShack? I dont know but if you do pls pass the information because I can't see this small part costing that much, because the ecu itself is expensive and if you buy a used one from ebay it'll cost you $120 and who knows when that one will crap out, so this is the best way to go, I'm sure the relays haven't gone bad. Any info is greatly appreciated.
Trying to search the net...
Baby,
I found a couple of places that recognize the number.
Show no stock and to call, but maybe they can get you in the right direction.
Advertised for 154 pennies. Not bad.
http://app.arrownac.com/aws/pg_webc/...rch_type=click
Found this one too, but it looks like they deal in bulk. ($100 minimum?).
http://www.ipacgroup.com/google/clic...FQINPAodXVpz9w
I hope it helps,
John
I hope it helps,
John
Thanks John.
I'm going to look into it and see if they can steer me the right way in the meantime for any of you guru electronic geniuses, if you know where I can go purchase one of these please let me know, Its getting worst to drive my clk i'm all cramped up, fuses keep blowing seats are to high and to foward, its getting out of hand, almost as if this car had a mind of its own.
I wonder if this part will work BTS409L1E3062ANT
<http://app.arrownac.com/aws/pg_webc/0,4513,,00.html?application=SEARCH&event=1000&sear ch_token=BTS409L1&search_criteria=match_begins_wit h&match_in_stock_only=NO&=&rows_to_display=10&full _domain_name=app.arrownac.com&super_neda=&start_in dex=0&search_type=click>
BTS409L1 Supplier
http://parts.digikey.com/1/parts/572...-bts409l1.html
It looks like they order them from somewhere else - not on hand, you'll have to call them.
well, I have to fix mine now...I'm guessing this is still relevant!?
DISCONTINUED...I just called them
from England:
Hi,
Thank you for your enquiry, can quote as follows:
1 GBP = US$1.55 = Euro 1.25 (approx)
BTS409L1,INF/SIE,ZIP
GBP £6.75 EACH + VAT 17.5% (if applicable)
You can order and purchase this part by clicking here:
http://www.littlediode.com/components/BTS409L1.html
Delivery in 10-14 days from time of cleared payment.
Regards
Zack
Hi,
Regards
Zack
Is this module pictured located under the seat or in the door?
Any suggestions?
Any suggestions?
from what I understand its the seat control unit under the seat. I've gotten under there and took everything apart and played with all the plugs...checked out everything and it seems that something is bad inside the seat control unit b/c when I flip flop the relays, my seat will actually go back and forward.
The module itself is $330 from MB (my price) and almost $500 retail.
I have found a workaround for this problem.
I press the control button back and down the same time (press down the back side of the button, like turn it anticlockwise for the left seat).
Then it can move back.
If you try just back first, and you have move more than 2-3cm the seat front, then workaround does not work anymore. Take off car key for about 10min to retry the workaround.
I don't know if this workaround works for other MBs too. Sorry for my bad English.
Regards
Stelios
Regards
Stelios
so I bit the bullet and bought the $600 part from the dealer (driver seat ecu/control unit) and it didn't fix *****
So I took it back out, flipped a few plugs around and now my up/down function makes my seat slide back and forth. Must be the switch that's fkin up. But now I have this control unit with no purpose.
If anyone is interested in purchasing, shoot me a PM
CLK W208
If you are looking for the passenger side module, i have a passenger side seat control module it perfect working order, i just tested it a month ago because i tought i had a faulty control module but it turned out that i had a wire that was loose. i'm willinng to sell the passenger side control module for $150 shipped. i paid $275 for it but hey i don't think i will need it and its just taking space. pm me if you want it. thanks
Can you please tell me how to flip flop[ the relays on the seat control module? what they look like?
I pulled the lever to let my son in the back on driver seat, seat went forward, however when I let lever down, seat did not slide back. it is stuck in forward position and seat will not recline all the way back. Dealer told me today need a new seat control module over 800 installed. seat will rise up and down, recline back only a certain portion however fore/aft will not work, and dealer thinks this part of module is nto working.
maybe if I can flip flop relays I can get seat back and it will allow me to recline back, i am 6 ft so I cannot drive, andyhelp on flip flopping relays to get seat back would really really help
