How do I check my automatic transmission fluid?
Old 08-11-2007, 08:42 PM
Almost a Member!
eddyhascal22's Avatar
1999 CLK430
Pics would be helpful. Thanks. Seems to hang up in 1st too long sometimes.
Old 08-12-2007, 01:22 AM
MarcusF's Avatar
2002 CLK430
You'll have to buy a transmission dipstick and an infrared thermosensor. If it hangs before the car is warmed up, it's supposed to.
Old 08-12-2007, 02:24 AM
Hary Gahtoe's Avatar
R230
MB Trans are "sealed unit" Like Marcus said there is a MB trans service level dipstick you put in the tube at the back (just off center) of the motor. If you're careful you can remove the sealed cap on top of the trans tube. Otherwise you'll need to buy a new one. Its got a one way pinch collar that holds it in place The service tool is a braided flex with a plastic indicator at the business end. Its not meant to be left in which is why the re & re sealed cap. Service tool goes for less than $30 , cap like $3-4
Old 08-15-2007, 02:22 PM
tripz's Avatar
00 CLK 430 Cabriolet
dipstick question
Ok I bought the dipstick and the dipstick only goes down part way. Are you saying that the car has to be running and warmed up prior to checking the level?
Even with the service cap removed on the top of the transmission, the dipstick wont go down all the way. Please advise
thanks,
Jim
Old 08-15-2007, 11:30 PM
R230
OK. The service dipstick should read both cold, (low level mark) and operating temperature.(driving temp)(high level mark) Low mark on the plastic gauge end is cold. If you don't show fluid, it might have caught the inside of the trans. So about the length of the dipstick, the fluid level will tell ya if its too short. I mean it should show fluid. A MB trans packs an exact amount of fluid and stay at a constant level unless it leaks. P.S. don't warm it up. You want a cold reading first, then an operating temp. Low & high mark.
Old 12-15-2008, 07:54 PM
gn3
gn3's Avatar
CLK430 Cab 03
I need some advice, I drained my ATF 2 days ago with an oil extractor and got 2.7L out. So I filled it up with exactly 2.7L of ATF from MB. Today I got a dipstick and checked it after driving for 45 min. The level is above the to 80C mark.
How do I know when the transmission it at 80C, it that regular driving temp?
I'm getting ready to take some out but I don't see how I could have over filled it.
Any ideas?
Old 12-16-2008, 02:53 AM
xmodrelic's Avatar
2kCLK320
I think the temp gauge on the dash has 80c on it and I'm pretty sure that's normal operational temp. Let your car idle or take it for a quick drive. If your not driving hard and its not really hot out the cars temp should hover right at 80c. I'm not 100% just check your dash.
Old 12-17-2008, 12:44 AM
MBtech87's Avatar
190e 2.6, 5-spd
On your .6 trans, just warm vehicle up after putting fluid in, and make sure you run thruogh the gears a few times.. the dipstick isnt supposed to go all the way down, you should have about 1-1.5ft sticking out still. If the car was just started, you want it right at or slightly above the 20*c mark, and if its been running right at or slighty below the 80*c mark.
Old 12-17-2008, 05:15 PM
gn3
gn3's Avatar
CLK430 Cab 03
I gave in and bought an infrared thermometer for $20, I'll let you know in a few days if the engine temp is a good indication of the tranny temp or not.
Old 02-27-2010, 07:23 PM
Pancho's Avatar
2000 CLK430 Cabriolet
The MB procedures, being what they are, I want to be certain about how to check the transmission fluid. So, some basic questions:
Do I check the fluid when engine is running ?
Do I check the fluid in Park or neutral, or what ?
Thanks\
Old 02-27-2010, 09:24 PM
gn3
gn3's Avatar
CLK430 Cab 03
I check it with engine on, in park, on level ground. My suggestion is at least 30 min drive to get it up to 80C. In my opinion the tranny takes longer to warm up than the engine.
Old 02-28-2010, 03:38 AM
Pancho's Avatar
gn3, hey, thanks for the advice. That's what I thought, but, this car has me wary of common sense, so, I expect some mystical Teutonic method of doing otherwise common things. It's reassuring that I can check the Trans. fluid in the old fashioned, normal, way. Again, thanks.
Old 02-28-2010, 01:25 PM
Pancho's Avatar
Here is some additional info.
I needed to know exactly how much length of the dipstick tool went into the dipstick tube, in order to check the fluid level. Dipstick would stop, sort of jam, and it took a considerable force to get it to continue again. I was concerned that, though unlikely, I might be pushing hard enough that the dipstick was turning and running parallel to the trans pan.
After tinkering and measuring, for what it's worth, the dipstick tool in the W208 722.623 Trans. should travel 25 inches into the dipstick tube.
There it is. Another Gordian knot undone.
Old 08-08-2014, 11:58 PM
WILLYWESTSIDE's Avatar
2000 CLK 320 BLACKOUT
Resurrection of old thread
Hey fellas
Im fairly new here but owner of CLK 320 hard top and clkk 430 convertible. I had a few questions and I can maybe answer review of yours if you have any but in regards to the dip stick. So from cap all the way down is 25 inches to get proper reading on trans level? And will it be the same for 320 and 430? 722.6 trans?
Quick Reply: How do I check my automatic transmission fluid?
