Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK-Class (W208) 1998-2002: CLK 200, CLK 230K, CLK 320, CLK 430 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: CLK430
CLK 430 YR99 LOCKED TRUNK HELP
#2 |
Drives: 2000 CLK 430 AMG Package
I have the same problem
did you find a solution, I have the same problem..........
Trunk will not open and the barrel lock wont turn....
__________________
2000 CLK 430 AMG Package |
#3 |
Drives: 1999 Mercedes Benz CLK430
same problem
__________________
1999 CLK430 |
#4 |
Drives: CLK430
No Results Yet
I haven't gone to have it looked at yet. I am a little reluctant to spend a $1,000 just for someone to open my trunk. I don't have any answers yet.
#5 |
Drives: FIA approved Pumas
You haven't listed where you are, but if you're in the US, you can call 800 Mercedes-Benz roadside assistance. I believe they’ll send someone out to open your trunk. Other than that, many have been in your position. Some patience and the key will open it.
#6 |
Drives: 2000 CLK 430 Cabriolet
Damn trunk locks *grumble*....how many guys is this now (w/the same problem)? When i had mine changed out, i had no idea this was so common!
__________________
Mods: Floor mats.... |
#7 |
lock is completely siezed.. key will not turn it... cant even get the key in..... yeah... 1200$$$ at the stealership... yeah... rapists....
__________________
#8 | |
Drives: 2002 CLK430
Quote:
back seat armrest folds down....u'll see the plastic box/housing hit it in (rubber hammer) or fist....it will goes eazy, push it in the trunk , ther is ur opening.......good luck.
__________________
Leave and let leave ! |
#9 |
Drives: none
So does this work for you?
I'll try this next time.
__________________
[IMG]http://www.******************/storage/411.jpg[/IMG] Like MBWorld |
#10 |
Drives: none
This is my prolem too.
Thanks for post. Thank you so much for the post. It's really useful. This is an interesting discussion. thank you for sharing ![]() ![]()
#11 |
from the exterior, Just PULL up really HARD!~
i popped a CLK trunk open w/no key at a wrecker and found some nice goodies that were left over by the previous owner! (3 crips 20 dollar bills and a small stash of drugs in the CD changer area!)
__________________
![]() DROP&DESTROY!!
#12 |
Drives: 2001 clk 55 amg
trunk won't operate?!
hey man, last week my battery died and the same thing happened to me ...i could not get into the f-in trunk to jump the battery.....manual key would not open it....tried evrything you did crawling thru the back seat to get to the emergency release...no power=no operation of electrics.....get a battery jumper to energize the system... there is a covered positive terminal next to the fuse box under the hood...hook it up.... find a GOOD ground to energize your electrical system....pop/unlock the trunk to access the battery and go from there to jump or charge your battery...good luck!
#13 |
Drives: CLK 230komp
Hello. Had the same problem with my CLK over here in the UK.
The problem is that the key doesn't get used ever. Im sure like me, every1 uses their remote key fob to open the boot/trunk. The locking mechanism gets stiff through lack of usage. The following worked on mine & should work on yours: Get some WD40 and using the straw, squirt some lube into the mechanism. Having put the key in the lock minus the black fob, use a pair of pliers and slowly turn the key left & right being careful not to snap the key in the lock. After a few turns, the lock should open.. Hope this helps. |
#14 |
Drives: Supercharged CLK430 street/show car
U can jump the car from the front
First you can jump the car from under the hood, theres a little black box on the driver side that connects to the battery. I get in and out of my car all the time and I have no battery i use the little key, insert, turn to the left and push in and wolla!
#15 |
Drives: e500
Is there any solution to these problem I did get it open with the key and using Wd40, but it will not open by pushing it anymore ....
#16 | |
Drives: "Sold 2000 CLK 430", 2003 CLK 500,2006 Acura MDX,1998 BMW M3 convertible
Quote:
__________________
#17 |
Drives: bmw/mercedes benz
if you can remove the first aid kit. there are square holes under the kit. get some bailing wire and form into a loop, an find were the rear seat release cable connect and put the loop on the end and pull hard. if you can not get it to move, wrap the other end to something to make a handle and keep tugging it should pop an fold down.
#18 |
fixing a mercedes benz sucks donkey butts. You cant get the scanners for mercedes to work, and less infomation in how to fix em. and still costly to repair. takem to a junk yard sell for scrape metal. I sold mine two weeks ago.
#19 |
mercedes benz cars are junk, expensive junk. get rid of it an buy a bmw.
| Tags |
| 2002, 430, backseats, clk, clk430, fuse, key, lock, locked, mercedes, open, remove, start, trunk, turn, wont |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
