Headrests, rollbar will not reset
Old 05-16-2009, 06:51 PM
gn3
gn3's Avatar
CLK430 Cab 03
Halfway through putting my top down it stopped, I had to move it manually. Now the headrests are suck in the up position. I've tried holding the up button for 20 sec, it makes noise but will not unlock them. Has anyone had this problem?
Old 05-16-2009, 11:24 PM
dennisspeaks's Avatar
2000 clk320
stuck
I have no idea how to help you, how do you put the top in manual mode, this info would be helpful if it ever happens to me.
D
Old 05-18-2009, 01:05 PM
gn3
gn3's Avatar
CLK430 Cab 03
It's in the manual. There is a tool in your trunk to release the bow latch (ceiling of trunk) and the top storage compartment latch (between back seat and compartment. You also have to turn a screw in your trunk, in the back along the base there is a hidden compartment that will provides access. Counterclockwise to free the top. The rest is just manhandling your top.
Old 05-19-2009, 12:41 AM
gismo3x's Avatar
2000 CLK 230 convertible
trunk
How did you open the trunk?
usually when the rollbar is stuck the the roof will not work and the trunk will receive the order not to open.
Please don't tell me with the f... key cause i tried in mine and I just can't get the trunk to open.
As for the noise you here in the trunk when you try to reset well I read a reply here on the site about that.
Someone posted the same problem and got it fixed.
Old 05-19-2009, 10:16 PM
gn3
gn3's Avatar
CLK430 Cab 03
Yes, the key is the only way to open it. I had to spray some lube in the lock and molest it for about 10 minutes to get it to turn. Your other option is to extract a tail light to get access to the trunk. Basically destroy and rip it out, I read a post where someone did it.
Old 05-20-2009, 01:25 AM
gismo3x's Avatar
Thank you for your reply.
I already fixed my problem but the funny thing is that I had to take off all the back seat, the center speaker and basically everything just to get to the trunk.... and I didn't.
But I could reach that small ship by inserting my hand through the seat speaker and replaced it. Suddenly everything worked,. like magic. I still have to fix my trunk lock though. I read the ship replacement thing on the forum but just can't remember who.
Old 05-20-2009, 01:28 AM
gismo3x's Avatar
check pix.
Old 05-20-2009, 08:52 PM
gn3
gn3's Avatar
CLK430 Cab 03
I took the back of the seat/trunk apart and still can't get to the roll bar mechanism, it's covered by metal. I figured out that I can push the down button and sit on the roll bars to get them to go down. However they still re-deploy. Does anyone know how this mechanism works?
gismo3x: How do you take the back seat out, can you see the roll bar mechanism from there?
Old 05-26-2009, 12:14 PM
Missinlinc's Avatar
Location: GA is home but the Army has me in San Antonio
2000 CLK 320 Drop Top
I was going to suggest that the problem could be the relay, but looks like you already found it ! Glad this helped you out. Seems like this issue is becomming more and more common!
Old 06-05-2013, 10:49 AM
edgar1's Avatar
2002 clk 430 Mercadez
please any ideas mine top no work and my roll bar moving up when try to open mine top
Old 06-05-2013, 11:19 AM
edgar1's Avatar
I'm attempting to open the top. I press the switch to open and the top doesn't move. However the roll bar does. When I press open it goes up and close it goes down. But the top still will not open. Does anyone know what the problem is??? And/or how to fix it??
Old 07-20-2019, 03:45 AM
Paul Westt's Avatar
Mercedes Benz clk convertible
Hi you put the key in turn it to the left release the turn to the right and push button in at the same time if it doesn't work squart wd40 in the whole and Keep trying it will free up in the end
Quick Reply: Headrests, rollbar will not reset
