Roof Molding removal
Old 07-05-2009, 10:37 AM
NFSCLK's Avatar
RED CLK 430 Coupe
The clear coat on the roof molding is coming off and I want to re-finish it. Has anyone removed the molding, it looks like it would just lift off from the rear end of the car.
Not sure Help!
Old 07-25-2009, 08:21 AM
NFSCLK's Avatar
RED CLK 430 Coupe
Roof Molding Clear coat coming off Am I the Only 1
I can't believe no one else has had this problem 91 of you looked at this post
Come on...
Old 07-25-2009, 08:45 AM
gregory13lil's Avatar
2000 CLK430
no prob here so far (knocks on wood)
GL
Greg
Old 07-25-2009, 03:21 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Sorry I have no roof...
Old 07-25-2009, 04:16 PM
lukemcv's Avatar
W208 CLK 55 AMG
Do you mean the painted strips on the top of the car ??
Old 07-26-2009, 10:41 AM
NFSCLK's Avatar
RED CLK 430 Coupe
Roof molding
Yes that would be called molding according to the man at the body shop who wanted $300 to replace.
Old 07-28-2009, 12:44 AM
unlukky's Avatar
2019 E450
Mine is doing it too. I have never personally done it, but when reading it seems the consensus is just what you guessed. " Pull up starting at the rear " They 'should' pop right out.
Old 05-22-2014, 12:40 AM
Composure's Avatar
CLK 55 AMG
How do you reaattach the molding? I bought the clips from the dealer but have no idea how to use them?
Old 07-28-2014, 10:39 AM
benningtonr's Avatar
CLK 320
Did you ever get them installed, I had one pull off in a carwash. I need to have it repainted then try and figure out how to install the darn thing.
Old 07-31-2014, 09:33 AM
myworld's Avatar
'02 CLK 320 2000 clk320
they just pull up. start from the back. Buy clips from dealer because these clips brake alot. easy to reinstall. the new clips are the red and white ones. they snug in place by the lil tooth slide on the clip them the rail goes in.
Old 08-04-2014, 11:11 AM
jonUF02's Avatar
2015 GL550 4matic
I taped around them and painted in place. I used the Dupli-Color spray can from local auto parts store, the Chrysler color that has been mentioned before. I can get the number if you need it. I wet-sanded, then base + clear. I did this on one side and it looks great, can't tell. I may end up doing the A-pillar as well, it's starting to fade, and it's a similar plastic part. I used it for replacing one of my washer nozzle covers too, can't tell the difference.
Old 01-10-2015, 02:14 AM
HawaiianC350's Avatar
C350
How do you remove them? I just want to make sure I don't snap, kink, or damage it in anyway.
Old 01-16-2015, 01:12 AM
myworld's Avatar
Go to the back of the roof trim and pry upwards you wont break them.
Old 01-24-2015, 06:25 PM
C350
Thanks!
Quick Reply: Roof Molding removal
