Location Of Amp
2002 CLK 55 AMG Coupé
It might be different on cabs, but on the coupes look behind the trunk lining on the driver's side. The amp has heat sinks but otherwise is dinky - and light weight.
Also is there anyone who knows if theres is much benefit from upgrading just the amp, with factory speakers?
2002 CLK 430 Cab.
Thanks for all the replies. It is definatly not in the L/R. On the cab that whole aera is cut short by the top well. It must be somewhere else...Jim
If you mean using a non-BOSE aftermarket amp with BOSE speakers, there is a well known problem in doing that. Every BOSE speaker I’ve seen has an impedance of about 1 ohm. Most non-BOSE car audio components are rated at 4-ohm. If BOSE speakers are connected to a standard 4-ohm amp, and the amp can’t handle the 1-ohm load (it can’t), it’ll fry the amp. The speakers will be ruined as well. BOSE uses their own proprietary specs for speakers and amps. If another manufacturer’s speakers or amps are used, the signal is usually kept separate from the BOSE speakers and amps.
Marcus is right (as usual). Besides, the speakers are not very good. Upgrade both.
BOSE = Buy Other Stereo Equipment
i have a clk 98 mod and cant find my amp! there is an amp or? i have no idea if there is an amp in my car!
i have checked the trunk, nothing there, also fornt by the drivers side, cant find it! any ideas?
there goes thick wires from my rear sub speakers to my cd player, thats about all i know.
need help! got to deliver the car to fix my exhaust tomorrow morning!
clk320 clk430 ml320
Bose amp location 2000 CLK430
It's an old post but I notice no response to the last post and a image is much easier.
This is the Bose AMP location on a 2000 CLK430 Coupe, rear trunk well- left side.
Only if you have a BOSE premium sound system.
Bose AMP -Trunk left side CLK430 coupe
