ALARM ISSUES, NOW WHAT TO DO
Old 04-21-2010, 03:24 AM
hope's Avatar
1998 ML 320, 2001 C 240, 2002 CLK 320
Ok so I have replaced the Siren and the PSE Pump and the alarm on my car still will not work. If I press the panic button on the Key Fob the light on the car flashes continous, however no alarm sound. What else can I check/ replace. Thanks
__________________
Old 04-24-2010, 05:41 PM
hope's Avatar
Dooes any one know what I can try next? Thanks.
Old 07-16-2016, 04:05 PM
Nw208clk32's Avatar
W208 2000 Clk 320 cabriolet
Did you fix this? I have a question. Did you use your exact same pse pump model and did you try a used one by chance. I just put a used one in my clk. It sthe same exact pse unit. I think it was ou of an e class though so I dont know if I still need to get it flashed for my car specs. And CPU. I did fix my locks and alarm by installing a pse that matched my same model number it was actually plug and go I just am concerned if it was a different car that it was originally installed that I might make something get messed up by using. Without flashing to my car first.
Quick Reply: ALARM ISSUES, NOW WHAT TO DO
