Lamp Defective warning light - NEED HELP
Old 03-04-2016, 11:29 AM
Spaceman33's Avatar
2000 MB 320 CLK
Found my unicorn
First bulb I found "defective" was the left rear brake light. Previous owner had installed a single filament bulb when a dual filament bulb was required. I changed out that bulb and still had the warning light. Went back to that location and found that the single filament bulb had pushed the two contacts down. Once I bent them back up, viola! Warning light gone.
Thanks for all the help and advice
Old 03-07-2016, 10:21 AM
cindyclk's Avatar
Had similar issues..mine was intermittent....turned out to be front side marker...tapped it and it came on....bent the contact and problem disappeared.
Old 12-10-2016, 07:37 PM
rchang1967's Avatar
1998 Mercedes Benz E320
This was the bane of my existence.
I finally figured it out. It was 2 of them. The first was a wrong bulb in the passenger rear tail light where a large sized reverse bulb was incorrectly in there. I replaced with the correct bulb. This was a step in the right direction with the help of my electrical engineer guy, Paul Albino of South Windsor, Connecticut and the part from NAPA of South Windsor.
The second was much more tricky. It was the passenger side vanity flip down visor light....which I normally would NEVER think of using nor checking.
I just found it.
Now, I have to get the bulb or fuse or just simply replace out the whole passenger side vanity flip down mirror.
Old 12-11-2016, 04:23 PM
shadenfroh's Avatar
It's late, so I can't really be bothered to do a search, but the plastic assembly should just pop off and the bulb should be a standart festoon.
Old 10-27-2018, 11:23 AM
Matt@'s Avatar
W210
Originally Posted by carrac89
I have a "LAMP DEFECTIVE CHECK LAMPS" warning that comes on when I turn my lights on, but none of my lights or lamps are out. How can I turn this warning off?? or what do I need to check..
Thanks for any assistance...
Cynthia
me2, my W210 tail light intimately "lamp defective" has been frustrating me quite a long time.
I change new sockets, pairs of "osram bulbs", and soldering each connecting from each socket to the plate. Problems are still persist....
You cannot imagine the root cause is due to the wiring plug connecting to the tail light house.
I applied the underneath WD40 contact cleaner, the problem is gone.
I almost consider going to buy a new LED tail light housing at aftermarket, thank you WD40 who saved me bunches of money.
Old 06-17-2022, 12:24 AM
Evansaero's Avatar
2002 C32 & 2011 E63
I know it's a super old thread but wanted to add to it. 2003 CLK 320 Convertible w/ 200K miles.
Check Lamp warning when depressing the brake after start-up (Tried replacing brake stop switch = did not fix the problem)
Selection of Lamp Control Module to (R) rear fog or Headlight while depressing brake caused the car to "turn on" same as ignition switch position 2.
From time to time N7-1 Fuse #7 blown (Right Rear Stop lamp)
Replaced Lamp Control Module and it fixed all the issues
Quick Reply: Lamp Defective warning light - NEED HELP
