H6W / 64132 LED City Light - W208
#76
E46 BMW M3, W208 CLK55
#79
Look back far enough in this thread and you can deduce when I bought these.... just last night I got a lamp error and one of my city lights is indeed out.
May just need to be reseated, but in the off chance that it does indeed need to be replaced.......can you PM me ordering instructions
w208 city lights.... thanks!
#80
SPONSOR/MBworld Guru
#81
Removed the light. Looks like the solder point on one of the LEDS has come loose, probably just from bumping and jumping around the city.......
Looks like I should be able to solder it myself and be back to good as new!
Thanks!
Thanks!
#86
1993 300SE (sold); 2000 CLK320
what's the feedback on your bulbs
how's it compared to others out there? (non e-bay items)?
I am looking to replace the oEM 64132 bulbs.. Thanks
#87
Ours uses high temp gel coat to isolate and insulate against heat related issues. We're also one of the few 5000K pure white out there. There's an easy 1 year warranty on our units. And you'd be supporting a forum vendor which helps keeps the forum lights on.
#89
W208 lights
Hi,
I would like to buy your led h6w city lights for my clk w208. It has an amg body kit with amg fog lamps.
Also what halogen bulbs low and high beam that would you recomend that will have the best color close to your leds.
Any suggestion on the fog lamps and plate lights. Can I get an offer for all as one order.
#90
responded to your PM
Hi,
#91
1 Post
'00 Mercedes 430/55 clk cabriolet
Hi!
I bought your side (city) lights a couple of years ago and they're still going. I do however get a bulb out error code which I've learnt to live with.
What I'd like is a recommendation for LED front headlight indicators..
All my bulbs are LED except those. I have seen you stock bulbs replacements but would they be suitable for my W208? I'd like a good intense spread of light.
Many thanks!
Many thanks!
#92
According to my specs, front signals use 1156 for your 2000 CLK430. That's US spec though and things potentially could be different with EU spec. Safest approach would be for you to pull out your stock bulb and check yourself (1156 has single base filament and key pins directly across from each other on the base), or email (aznoptics@gmail.com) to us a few pics of the base so we can identify for you.
#96
AZN Optics is now offering next generation Morimoto XB35 HID conversion kits. Available for order on our site www.aznoptics.com or PM us for more details.
#98
Monthly Bump.
Just a reminder, rear plates use a set of 36mm festoon LEDs!
