Instructional: Install Motor Mounts
Old 10-29-2011, 03:28 AM
Pancho's Avatar
2000 CLK430 Cabriolet
Instructional: Install Front Motor Mounts on Year 2000 CLK430 Cabriolet
Did this job last week.
Now have a smooooooth CLK.
Attached Thumbnails Instructional: Install Motor Mounts-1-page-1-intro-mtr-mnt.jpg   Instructional: Install Motor Mounts-1-page-2-jack-under-motor.jpg   Instructional: Install Motor Mounts-1-page-3-mnt-removed.jpg   Instructional: Install Motor Mounts-1-page-4-mnt-pin-align.jpg   Instructional: Install Motor Mounts-1-page-5-done.jpg
The following 2 users liked this post by Pancho:
ChineyPelon (02-17-2024), Mikeoxlodge (03-09-2017)
Old 10-29-2011, 04:45 AM
Pauljay's Avatar
'00 Mercedes 430/55 clk cabriolet
Nice write up!
Old 10-30-2011, 04:40 PM
dlbehrns's Avatar
99CLK320,
Appreciate your work Pancho. The part number brings up several model applications and the w209 in particular via google. I've read on this forum on more than one occasion that the 209 part is superior to the 208. What I didn't see was whether the part applies to v-6 as well.
Old 10-30-2011, 08:31 PM
MarcusF's Avatar
2002 CLK430
Thanks for the write up Pancho
Old 10-30-2011, 09:05 PM
Pancho's Avatar
You are most welcome, gentlemen.
My pleasure.
Old 10-30-2011, 09:08 PM
dlbehrns's Avatar
99CLK320,
I should have posed the question: is the part number in the first thumbnail applicable on the 320?
Old 10-30-2011, 09:17 PM
Pancho's Avatar
I don't know. But, logic follows that, if the OEM motor mount part numbers for the 430 and the 320 are the same, then the W209 mount will fit the 430 and the 320.
So, the new question: Is the OEM motor mount part number for the 430 and the 320, the same ?
Old 11-03-2011, 10:20 PM
slobodan's Avatar
1999 CLK 320
Not sure but the part numbers for the 320 are as follows...
Front: 230 240 05 17
Front : 230 241 04 13
As listed on EPC's site
If I had a 430 vin I could look it up.
Old 12-17-2012, 01:21 AM
OGCLK320's Avatar
2004 E55 AMG, 2008 G55 AMG
Did anyone ever find out if the 209 engine mounts will fit the 320 motor as well??? I am about to buy motor mounts and want to buy the 209 mounts so they hopefully last longer. Any help is greatly appreciated.
Old 01-19-2013, 07:14 PM
torezcoleman's Avatar
99 CLK 320
Money saver
As long as you don't mind getting your hands dirty and spending time fixing your car this is a fine DIY. As everyone says the driver side is definitely more difficult you'll need a 5/8 for the top bolts. For the driver side I removed the windshield washer reservoir and also had to move the compressor (with hoses still attached)....the passenger side was a lot easier I just removed the air filter and it's box,I also removed the alternator for easy positioning,don't torque the nuts on the back of the alternator to much,I broke the Smaller one and ended up having to drill a hole into the broken screw and screwing a smaller screw into that,rigged,but better then spending unnecessary money IMO.While under there check to make sure you put the hoses securely back on the reservoir and on the top to,because strangely one of the hoses to the reservoir has antifreeze coolant coming from it. I changed both of these motor mounts and the car still shifts gears rough sometimes,but the motor mounts are secure and the engine no longer has play in it,so the only thing left is the transmission mount which is said to be very easy. I appreciate all the help I've found and hopefully this will be extra help to someone
JAMD522 (06-17-2022)
Old 05-24-2014, 05:14 PM
njgilligan's Avatar
2001 CLK55
Definitely a very doable DIY. I found it easiest to get all the bolts from under the car with some extra leverage necessary to break loose the top bolts. Took me 1.5hrs including jacking. Thanks Pancho!
Old 05-25-2014, 12:10 AM
Pancho's Avatar
You are most welcomed.
Old 08-27-2014, 12:58 AM
Zundfolge's Avatar
None. Sold the last one and never looking back.
I'm not a cussing man, but here goes....
mother****ing goddamn **** ant piece-of-**** Mercedes. This is my last one. I swear. If you're reading this and thinking about buying one, don't. I just traded my 2004 W211 E320 Estate for a Camry. Never looking back.
Now for this...
Who puts a 16mm bolt there??? I have been trying for over an hour to get them loose. If you reach up with one arm to find it, you can't reach up with the other to secure it. And I'm very much not a weakling. So many times this has been an issue. These things are overthought and break too often. I'm done.
Old 08-27-2014, 02:13 AM
Zundfolge's Avatar
And putting it back in. Could they have possibly used longer damned bolts??? Srsly.
Old 08-27-2014, 02:57 AM
Zundfolge's Avatar
...and then you drive it. Feel a little better. Not much.
Old 08-28-2014, 11:49 PM
Pancho's Avatar
Man up.
You're becoming an embarrassment.
Reggaerider (03-22-2020)
Old 08-29-2014, 02:43 PM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Does anyone know how much the mounts are in the UK from the dealer ? Also what are the w209 compatible ones for a CLK 230 Kompressor.?
Thanks in advance
Old 08-29-2014, 11:26 PM
Zundfolge's Avatar
Originally Posted by Pancho
Man up.
Like I care at all what you think.
RE: "Man up." Stop on by! Anytime!
Old 08-30-2014, 12:21 AM
Pancho's Avatar
So, now you're a cry baby and a jacka$$,
and in public.
What else big boy?
Old 08-30-2014, 05:10 PM
Zundfolge's Avatar
lol. Still couldn't care less what you think. Seriously.
You're the one who turned this personal. Easy to do behind a keyboard, eh?
Old 08-30-2014, 05:29 PM
A1EK's Avatar
Okay when you guys have stopped the biatchiin, thought you'd like to know that I replaced my engine mounts today, worked entirely from underneath the car, not too bad but I found I had to loosen some pipes as they were in the way.
Anyway drivers side mount was totally shot but then they have been on the car for 160K miles !!. New mounts fitted and the car feels like silk !!
Old 09-01-2014, 12:28 AM
Pancho's Avatar
More keyboard courage from the mouthy jacka$$.
Don't touch a wrench baby boy.
Better to pop a pacifier into your weepy mouth.
Old 05-18-2015, 06:02 PM
Bcmcmoose's Avatar
2003 clk430 cabriolet, 1970 Chevrolet c10, 2004 bmw r1150rt-p, 2015 bmw r1200rtp
Thank you.
Thank you for your Informative diy. I did both motor mounts and the Trans mount in less than two hours. The stealer had quoted $188 each motor mount plus $88 for Trans. I got them online for $88.50 for all three. Went right in and car is so smooth!
Old 06-11-2015, 09:28 AM
Flydutch's Avatar
Merc S55 AMG Kompressor 2003 & S320 1999
Hi guys, (From South Africa)
It is very difficult to get a proper write up on this issue and this one, with the sharp pictures, is brilliant. If I go to WIS/ASRA it says that you remove the serpentine belt, alternator, aircon compressor etc, etc, but I cannot believe that is required. I drive a 2003 S55 AMG Kompressor (205000 Km = 127000 Mile and I got body vibration at idle and at run between 2000 & 3000 rpm so I think it is the mounts and not the prop "Cakes"). To me it looks like this write up applies also to my car (Perhaps mounts as such different but I doubt it). Any take on this (Compatibility). Other posts make mention of removing the sway bar and/or steering rack, did you guys had to do this also or you managed it without it? The rear mount I did on a s320 and that was very easy.
Old 06-15-2015, 03:21 PM
sb53's Avatar
Just did my motor mounts today on my 2000 CLK430 Cabriolet using this DIY! Thanks Pancho! Great job! It took about 2 hours total. Didn't have to remove anything special. The toughest part was to break and tighten the top bolts. The only thing I would add on my model car is to unhook the battery so you don't create an arc if you touch the terminals on the alternator with your wrench (which I did for a split second). The car is smooth as silk again when idling in gear. My mounts were shot at 93,000 miles. So nice to be like new again! Thanks again!
Quick Reply: Instructional: Install Motor Mounts
