how to reset service indicator
Old 11-04-2011, 03:15 PM
Angel 430's Avatar
Just had my A service done but they forgot to reset the service indicator. Can someone please tell me how to do it myself.
Old 11-04-2011, 04:20 PM
Mob
Mob's Avatar
00' CLK 55 AMG
In the exact same situation, can someone explain how to do this?
Old 11-04-2011, 04:28 PM
gotabyte's Avatar
CLK320
http://www.youtube.com/watch?v=hISgSjyrK2w
Video of how to
Old 11-05-2011, 04:11 AM
joeljp's Avatar
2012 C63
The instructions are in your owner's manual.
Old 12-20-2011, 09:55 PM
dlbehrns's Avatar
99CLK320,
I followed the instructions under Flexible Service System in the manual and it did not work. I have no buttons on my steering wheel. Anybody?
Old 12-21-2011, 08:13 AM
cindyclk's Avatar
If you follow the instructions for the FSS reset in the manual, it will work...you have to be quick and it might take a few tries.
Get in the car and close the doors. Put your finger on the R button but do not press it yet.
Turn your key to the Run (ON) Position(ON but not started)
Now Press the R Button 2 times.
You will see the number of miles/days remaining for displayed.
Turn the key to the off position within a few seconds (do it quickly).
Press and Hold the R Button while turning the key back to the run (ON).
keep holding in the R button for 10-15 seconds more, you should hear a beep, and see that the system has reset the service interval.
Let go of the button.
Old 12-21-2011, 04:59 PM
dlbehrns's Avatar
99CLK320,
I did exactly what you suggested and what was in the manual. NADA! the number of miles or days does not display rather SERVICE DUE NOW. after the first step turned the key off, pressed and held the R button, turned the key to #2 position but did not start, and held for at least 15 secs, no beep, no reset. I follow instructions well becuase I give instructions all day long in a call center so I know I did it the way it should be done but it won't reset. Please dont tell me to take it to the dealer.
Old 12-21-2011, 09:40 PM
cindyclk's Avatar
Believe me, I'm the last one to say ..go to the dealer.
Are the doors closed?
It's been a while since I had my '99 but I'll try..when you press R twice...don't wait for the mileage to come up...press twice/off/continue to hold/back on...all within a few seconds
Old 12-22-2011, 02:55 AM
Flounder's Avatar
'99 CLK430
If I remember correctly you turn the key to position 2, press O twice, turn off and then quickly back to position 2 while holding R until it beeps.
Old 12-22-2011, 12:28 PM
dlbehrns's Avatar
99CLK320,
doors were closed cindy. will try the the 0 first then the R thanks Flounder "Toga, Toga, Toga!"
Old 12-22-2011, 09:47 PM
dlbehrns's Avatar
99CLK320,
Interestingly enough!!!!! I pressed the 0 button three times, held it down and turned the key to off then turned the key to #2 without letting up on the 0 button and it reset. Sheesh!!!!! Hope I can remember this the next time. Thank you all.
Old 11-08-2019, 02:16 PM
derekwh's Avatar
2012 E350 Bluetec, 2014 GLK250, 2007 CLK350 convertible
This is what worked for my '02 CLK55.
1. Turn on the ignition (standard display of the control system appears).
2. Press button (UP arrow) or (DOWN arrow) on the multifunction steering wheel until the FSS indicator with (Single Wrench) or (Double Wrench) and the service deadline appears in the multifunction display.
3. Press the reset knob to the left in the instrument cluster for about 4 seconds. Picture below.
4. [img]file:///C:/Users/Derek/AppData/Local/Temp/msohtmlclip1/01/clip_image001.jpg[/img].
5. This message appears in the multifunction display, DO YOU WANT TO RESET SERVICE INTERVAL? TO CONFIRM PRESS BUTTON. To confirm hold down the reset button until you hear a signal. Picture below.
6. [img]file:///C:/Users/Derek/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg[/img].
7. The service indicator now displays the reset interval.
Old 11-08-2019, 05:29 PM
jinark's Avatar
2003 CLK 320 convertible
Ditto on my 2003 CLK320 Cabriolet.
Quick Reply: how to reset service indicator
