Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W208)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-04-2012, 04:38 PM   #1
Drives: Clk320
Vacuum hose location on 320
I am trying to run seafoam in the car(01 clk320) and I'm wondering where the vacuum hose is located to perform this. Thanx
To remove this ad, register today or login if you already are registered!
Reiter is offline   Reply With Quote
Old 01-26-2012, 01:32 AM   #2
walnut82's Avatar
Drives: 01 CLK 320
i will be doing this tomorrow, if not, in 2 days tops. i will post pics or a video on how to do it.
walnut82 is offline   Reply With Quote
Old 01-27-2012, 01:19 AM   #3
walnut82's Avatar
Drives: 01 CLK 320
vacuum line is on driver side, back of engine compartment. its tough to pull out so be careful and use pliers. the hose is very stiff, if you cant get it upright pour the seafoam in a bowl and let the vacuum suck it in, remember do this slowly or you will kill the engine. use about 3/4 cup of seafoam, half in gas tank, turn off car and replug the vacuum line (make sure its back in tightly), let it sit for a half hour then run the car. rev continuously until all smoke is gone, drive around (hard) to make sure all the smoke is gone. there you have it. mine runs like new, after 200k miles it still runs like new. sometimes i wounder if its an AMG
Vacuum hose location on 320-imag0001.jpg  Vacuum hose location on 320-imag0327.jpg  Vacuum hose location on 320-imag0328.jpg  Vacuum hose location on 320-imag0329.jpg  Vacuum hose location on 320-imag0332.jpg
Old 01-27-2012, 09:39 PM   #4
Drives: 2001 clk 320
Niiiiiiiice walnut82!!! I've been wondering how to do this.will bedoing this asap tom.
jbenz2001 is offline   Reply With Quote
Old 01-27-2012, 09:43 PM   #5
walnut82's Avatar
Drives: 01 CLK 320
Quote:
No problem. Hope it helps. Let me know how it goes
Old 01-27-2012, 10:38 PM   #6
Drives: 99CLK320,
Did you use the whole bottle?
__________________
99CLK320-One day I woke up and my slab had morphed into a McLaren MP4-12C
INMotionusa Chip Tune, Sprintbooster,
VIPclk320's cold air ram intake and front & rear strut bars, Ghostrider's short tube headers and rear camber kit, MB front control arm camber bolts, Vogtland Springs, Bilstein Sport shocks, Goodridge stainless braided brake lines. Wish list: SuperSprint resonator and muffler, seconary cats deleted.
dlbehrns is offline   Reply With Quote
Old 01-27-2012, 11:26 PM   #7
walnut82's Avatar
Drives: 01 CLK 320
No I used half in the gas tank then 3/4 cup in vacuum line. I still have about 1/4 of the bottle left
Old 02-09-2012, 10:10 PM   #8
So I did the seafoam thing.it seems like the car drives smoother.but now my check engine light came on for my egr valve.
Old 02-10-2012, 10:29 PM   #9
Drives: 99CLK320,
Do you have a OBDII scanner? If not go to autozone and see what codes show up.
__________________
Old 02-12-2012, 10:48 AM   #10
Yeah I do.code p0400,p0130,and p0135 showed up
Old 02-12-2012, 05:25 PM   #11
walnut82's Avatar
Drives: 01 CLK 320
the seafoam does not go to the EGR Valve. i literally just got done with cleaning my EGR valve. the egr vavle (Exhaust Gas Recirculation). EGR works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. In a gasoline engine, this inert exhaust displaces the amount of combustible matter in the cylinder. its gonna be clogged up so you need to either take it to a mechanic or do it yourself and save about $450. heres a page for the diy, i will also add some pics to it.
EGR valve and hose DIY cleaning
__________________
Old 02-12-2012, 06:30 PM   #12
slobodan's Avatar
Drives: 1999 CLK 320
Here are your codes...
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0400 Exhaust Gas Recirculation Flow Malfunction
I would disconnect your battery and reconnect it to see if it clears the codes.
slobodan is offline   Reply With Quote
Old 02-13-2012, 10:24 AM   #13
Yeah mine also popped up once punched it on the highway.1st thing Im gonna do is clean the egr valve.
would you guys recommend me buy the hoses and gaskets first before attempting?the dealer is about 30 min away from and I would hate to attempt it on a weekend and need the piece.
Old 02-13-2012, 11:34 PM   #14
walnut82's Avatar
Drives: 01 CLK 320
thats by chance, lucky for me the gasket and the hoses were clean and i did not have to replace them. CAUTION!!!! be careful when removing the hoses because the inlets are VERY!! brittle. i broke mine but luckly i had epoxy glue and fixed it.
__________________
Old 02-14-2012, 02:12 AM   #15
Ok,thanks
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
1998, 1999, 320, clk, clk320, egr, engine, flow, foam, line, lines, make, malfunction, sea, seafoam, vacum, vacuum, w208
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
