You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hi , i've a CLK230 droptop, '98 Reg, v.low mileage.
Ever since I put the wheels on (3 years ago) I knew I should of changed somethin' extra like the suspension coils, because the new wheels were 2 inches bigger.
.. and now, after hitting a few pot holes, front driver-side wheel punctured once, and a few weeks later, the front Driver-side wheel is making a massive screeching noise AND the front driver side wheel is now sitting 1.5 inches lower than the passenger side.
The wheel makes a loud noise when I turn it a little bit, but when I turn it ALOT (more than 135 degrees) the noise disappears! However the noise is constantly there when I drive straight, its a loud screeching noise from the suspension parts.
What could be the problem here?
Would the Sport/Wet setting make a difference?
Also, more importantly what parts do I need to raise my car 1 or 2 inches?
Pictures to follow..
To remove this ad, register today or login if you already are registered!
Reason: to make it better?
