Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK-Class (W208) 1998-2002: CLK 200, CLK 230K, CLK 320, CLK 430 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: CLK 230 Kompressor
Vibration when first start in park, possible transmission mounts?
__________________
![]() 18x235x40 (8.5J) & 18x255x35 (9.5J) Brabus Monoblocks VI reps, Eibach Pro lowering kit, no#1 pad front zero rear. Rolled arches,20mm rear spacers/15mm front, Flat emblem, Kompressor skirt badges, Parking sensors, colour coded grill, front flat lip, front eccentric camber bolts, Denso Irridium plugs, K&N filter, Sony ICE adapted to steering wheel buttons, blue LED modified dash & interior. |
#2 |
Drives: a car ldo
Motor mounts most likely. If it were the tranny mount, you'd feel a vibration through the shifter/center of the car when loading the tranny.
There's only one tranny mount and it's a rubber crossbrace. Most recommend if changing the engine mounts, change the tranny mount too (especially @ 130k).
__________________
2003 CLK320 Cabriolet| K2A & K4 options Smoked sidemarkers | AZN Optics LEDs | Eibach Pro-Kit | Bilstein Sports | #1 W210 pads | Forgestar F14 | Nitto Invo | Uber rattly convertible top |
#3 | |
Quote:
thanks
__________________
#4 |
Drives: CLK 230 KOMPRESSOR
Change them both. You will not regret the feeling of a brand new CLK
When I got mine at 55k (kilometers) I thought it was perfect until I did a tranny and engine mount change. I said to my self - the Benz is now a Benz
#5 |
#6 |
Drives: 2000 CLK430 Cabriolet
You can get best prices on OEM at parts.com
Here are a couple of instructionals I put together. These are not difficult jobs. Front Motor Mounts: Instructional: Install Motor Mounts Rear Motor mount (Trans. mount): Instructional: Install Rear Motor/Trans. Mount on Year 2000 CLK430 Cabriolet
__________________
CLK430 Cabriolet, bought it new in year 2000, Chassis# W208, Trans#722.623, Engine #113.943 |
#7 |
Drives: 2001 CLK 430, 2004 E55 AMG
Change both the motor and tranny mounts! Just had this problem and now the car feels fresh! Good luck!
__________________
#8 | |
Quote:
#9 |
Thanks for the photos, I got round to changing the transmission mount, pretty simple, you just need to under 4 bolts, (2 x 13mm and 2 x 16mm) and swap. When I took the old one off it first looked okay, but I saw it had split and the gap was wider at the top, which meant the transmission was slumped down a little.
Now its replaced with a new one, the car feel sweet and tight again. No vibration in park or drive when cold and I also realised that as the exhaust is mounted to the side of the transmission it was being pulled down and causing it to vibrate a little which is now gone. ! Engine mounts looked okay for now, but will change them in due course.
__________________
#10 |
Drives: 1998 CLK 320 Sport
Gratz on getting your car sorted. Do you have any pics about the trannie mount, or any links to them?
#11 |
__________________
#12 |
#13 |
Good man.
I was just kidding. Glad you took it well.
__________________
| Tags |
| 2001, 2002, 320, 430, car, change, clk, clk230, installing, mercedes, motor, mount, mounts, park, transmission, vibrate, vibration |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
