Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W208)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 03-28-2012, 06:01 AM   #1
Drives: clk 230 w208
INSTRUMENT CLUSTER
I have few pixel issues on both the temp display and the gear display in the dash.
CLK 230, W208, 2001 Convertable
I've been told that I have to replace the whole instument Cluster (MERCEDES part no.: A 208 540 56 11)= $1700 Aud.
I found a guy on the net in europe that reckons this display issue is due to the ribbon cable, he tells me that a simplly replacing the ribdons will fix my pixel problems. And that after the cable replacement there is noting to do, no need to reprogram or recode anything.
http://pixelfix.net/eng/
Has any one done this?????
John
Update found a company that will do the whole refit with new LCD's and new ribbons for $185 -
http://www.speedlineinstruments.com.........I'm happy.
To remove this ad, register today or login if you already are registered!
john.m.gemmell is offline   Reply With Quote
Old 04-04-2012, 03:44 PM   #2
Drives: '01 CLK 430 cab
I just bought the new ribbon cables from this guy after seeing your post. I also pulled up the instructions on WIS and will do this when they come in. WIS says you need special tool 140 589 02 33 00 to remove the instrument cluster but I can make the tool and will let you know how this all goes!
__________________
'01 CLK 430 w/100K+ miles
Parts replaced/work done: throttle position sensor, brake light switch, combination switch, hydraulic cylinders for soft top, hydraulic pump oil, spark plugs, spark plug wires, motor mounts, transmission mounts, front wheel bearings, fuel filter, air filter, cabin air filter, oil filter, replaced muffler with straight pipes to dual outlet, rebuilt calipers, bled brake system, and I'm sure there will be more fun to be had!
BSconz is offline   Reply With Quote
Old 04-04-2012, 05:31 PM   #3
These guys do great work all over the world.....none in Perth but maybe you can ship it...5-7 days turnaround. I used them for missing pixels 2 years ago and the cluster has been fine since.
http://www.bba-reman.com/US/index.aspx
__________________
2010 GLK350 4Matic Paladium Silver
2002 black CLK 55,Lorinser roof spoiler, illuminated AMG door sills, Eurocommand by Steve, black birdseye maple shift ****/door handles/arm rest, quad exhaust
cindyclk is offline   Reply With Quote
Old 04-04-2012, 05:53 PM   #4
Pancho's Avatar
Drives: 2000 CLK430 Cabriolet
Used same vendor in 2008. Cluster has worked well.
Here are my notes:
May 10, 2008 Won ebay item number: 230250621016 on May 10, $225 + $20 shipping, total $245, shipped instrument cluster to BBA Remanufacturing Inc., 300 Myles Standish Blvd., Taunton, MA 02780, (866) 573-2740, us-sales@bba-reman.com, www.bba-reman.com Mon-Fri 9 am - 5:30 pm ET
Here's a link to my first fix. Lasted about 2 months, then started losing pixels.
http://www.panchogun.com/FVWebPhotos...ight-6x100.jpg
__________________
CLK430 Cabriolet, bought it new in year 2000, Chassis# W208, Trans#722.623, Engine #113.943
Pancho is offline   Reply With Quote
Old 04-05-2012, 11:20 AM   #5
lowphat's Avatar
Drives: 00 KLEEMANN CLK 430. Stares at: 88 Euro AMG 560 SEC Widebody
Here's another idea:
Click Here
I can't give proper credit for it because I've forgotten where I pulled it from. I also can't confirm how hard/easy it is, or how long it lasts, but it does eeem to be a logical and inexpensive solution to this common problem.
Good luck!
__________________
Enjoy yourself, Marco.
lowphat is offline   Reply With Quote
Old 04-06-2012, 12:54 AM   #6
Pancho's Avatar
Wow, that is really interesting.
Very good.
__________________
Old 04-06-2012, 05:16 AM   #7
SimplyBenz's Avatar
Drives: Clk 230 supercharger
Hi Guys, need some help with Instrument Cluster.
I had a few fused lamps in my cluster, which i changed. everything went perfect until i started the car.
Malfunction: Display Defective Visit Workshop!
step by step:
1. No key in ignition.
2. pulled out the IC.
3. disconnected the wire harness.
4. replaced the fused bulbs with new ones.
5. connected the wire harness.
6. placed the IC back in.
7. ignition on, started the car... PIIIIP,PIIIIP
8. MALFUNCTIONS Display Defective Visit Workshop, ESP,ABS!!!!
9. Nothing on my IC is working (clock started from 12:00 dosent show the gear, middle display shows the Malfunction msg ONLY, Temperature is stuck on -38, all the needles point down)
have tried:
*disconnecting the battery for 10min (no luck)
*did a ECU hard reset (no luck)
*went to a workshop to remove Malfunctions by an OBD thing. his computer said "Unidentified Electrical Error" (no luck)
he recommended to take it to someone who repairs IC's or to Mercedes (and both are pretty expensive here in Sweden)
any ideas how i can fix the problem?
Car spec:
CLK 230 kompressor (German Import)
manufacturing year 1999
model year 2000 (mid-facelift model)
SimplyBenz is offline   Reply With Quote
Old 04-06-2012, 10:24 AM   #8
Pancho's Avatar
What I would do:
1. Reinstall it. Sounds like a cable or connector is loose.
and/or
2. Reinstall it with the old bad bulbs. Might have an issue with the new bulbs.
Note. What do you mean by "fused"?. When a lamp burns out, the filament is the opposite of fused-it is broken, or interrupted, but not fused. I don't know what you mean.
__________________
Old 04-29-2012, 11:08 AM   #9
SimplyBenz's Avatar
thanks for the reply, it was one of the connector cables that was loose, Fixed it
Quote:
Originally Posted by Pancho View Post
What I would do:
and/or
Old 04-29-2012, 09:39 PM   #10
Drives: 2001 clk 320
Can somebody tell me what's the total cost of the cable.don't understand euro amount.
jbenz2001 is offline   Reply With Quote
Old 04-30-2012, 01:08 AM   #11
MarcusF's Avatar
Drives: 2002 CLK430
Quote:
If you mean from pixelfix.net, it's about $47 with shipping and they are a very fast shipper.
MarcusF is offline   Reply With Quote
Old 04-30-2012, 02:25 AM   #12
Nice,that's not to bad.thanks marcusf.im try that diy trick first before sending it out that lowphat provided to us.
Old 06-25-2012, 01:42 AM   #13
batozz's Avatar
Drives: CLK 430
Warning Lights Went on After Replacing Instrument Cluster
Regarding replacement of a 1999 CLK 430 (w208) instrument cluster, is it normal for various warning lights to go on right after replacing the cluster? I had no warning lights on the old cluster and changed it as my LCD ribbon was messed up. Once I installed the new cluster a few of the warning lights like BAS and ECU went on. The car is running FINE and I notice no performance changes since the lights went on.
My question is does the car have to be hooked up to a Mercedes computer to reset the instrument console and possible random lights after the cluster is replaced? Is it normal for the lights to even go on right after changing the instrument cluster?
Thanks for the help and I am about to take it in to a Mercedes mechanic but would like to know if a simple reset is in order to prevent him talking me into new mass sensors etc. I may not need.
Thanks for any help!!
batozz is offline   Reply With Quote
Old 06-25-2012, 03:38 AM   #14
if you have replaced the cluster
yep it needs to hooked up to the computer to get a reset.
Old 06-25-2012, 07:03 AM   #15
batozz's Avatar
Drives: CLK 430
Thanks for a clear, to the point answer
Quote:
Thank you for your prompt answer. I searched over an hour and could not come up with your answer to my question. Now I need to find a small shop that will reset it cheaply. Thanks again.
Old 06-30-2012, 05:23 AM   #16
Drives: CLS 500 (2005), CLK 500 (2005), SL350 (R230)
step by step:
have tried:
Car spec:
The instrument cluster doesn't like some of the after market bulbs, maybe try buying Mercedes ones of ebay or something. And check the cables too because sometimes the ribbons aren't making contact properly to the unit.
Take the unit apart again and put it back together, see if that helps.
sambam2006 is offline   Reply With Quote
Old 12-17-2012, 05:48 AM   #17
Drives: 2001 CLK 430 Convertible
Hello all....
I have noticed as of late my Instrument panel switches information by itself ?
1 min it shows my current speed, the next mileage, on two service info.
Any idea why it does this?
Also, I thinking of placing 20 inch Mercedes Rims on, any thoughts ? or concerns i should be aware of?
Thanks in Advance!
4thagnu is offline   Reply With Quote
Old 02-16-2013, 08:13 PM   #18
Drives: 2002 CLK 430
EC light with climate controls
The EC light on my climate control system stays on. What is the appropriate fix with this?
skycable is offline   Reply With Quote
Old 02-16-2013, 10:56 PM   #19
MarcusF's Avatar
Drives: 2002 CLK430
Freon.
But this question really should be in a different / unique thread.
Old 02-18-2013, 09:06 PM   #20
GatorMB's Avatar
Drives: 2002 CLK 55 AMG cabriolet
I purchased one here but yet to install it is coming soon
http://www.equipmentsfinder.com/merc...-shipping.html
$15
Gator
I tested the link and its chinese new year
GatorMB is offline   Reply With Quote
Old 02-26-2013, 06:06 PM   #21
Drives: clk200k
Exclamation
I just bought a CLK 200k 1999. I have a question about the instrument cluster check engine light. I don't know if the bulb is out, but I have no check engine light. When I put in the first possition only SRS on top left shows, in possition 2, I have BAS,ABS, Brake, the yellow triangle, oil, temp, water, etc, but I don't see any of the EML or Check engine light. The left side is fulll, the wright one has same empty and the bottom also. Dose anyone know where it should be, and if I have to remove the instrument cluster to fix this. Thanks
joniko76 is offline   Reply With Quote
Old 03-05-2013, 07:28 PM   #22
You mean "refrigerant" which is the proper term these days right? Just giving you a hard time Marcus...
Quote:
Originally Posted by MarcusF View Post
Freon.
__________________
No, there wasn't a CLK 430 AMG....
Scott Simoncic is offline   Reply With Quote
Tags
2000, 430, a208, clk, clk320, cluster, instrument, knob, mercedes, panel, pixel, pixels, problem, recode, repair, shift, wwwpixelfixnet
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
