Sign in using an external account
| CLK-Class (W208) 1998-2002: CLK 200, CLK 230K, CLK 320, CLK 430 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 01' S430, 08' C300,99 CLK 320 cab, 04' Q56
Replacing City-Light bulbs?
__________________
![]() 01 S430 [sold] 99 CLK 320 Cab 05 E500 04 Q56 08 C300 [sold] |
#2 |
__________________
#3 |
Drives: 99CLK320,
When you say city lights, which ones are you speaking off? The two smaller center guys?
__________________
99CLK320-One day I woke up and my slab had morphed into a McLaren MP4-12CINMotionusa Chip Tune, Sprintbooster, VIPclk320's cold air ram intake and front & rear strut bars, Ghostrider's short tube headers and rear camber kit, MB front control arm camber bolts, Vogtland Springs, Bilstein Sport shocks, Goodridge stainless braided brake lines. Wish list: SuperSprint resonator and muffler, seconary cats deleted. |
#4 | |
Quote:
yea those
__________________
#5 |
Drives: 2001 CLK 430, 2004 E55 AMG
No it shouldn't take removing the front bumper to do the job. It is really tight though, have you tried using needle nose pliers or tweezers?
__________________
![]() AMG Intake, K&N Air Filters, Koni Yellows, Eibach Pro-Kit (once I find a spring compressor), Resonator Delete, Muffler Delete, Quad tip exhaust coming soon, Yellow G2 Caliper Paint, LED Door Lights, Stock Chrome 17" AMG Wheels (Sprayed), Emblems/Grille (Sprayed), Drilled Brembo Rotors (coming soon) |
#6 |
Drives: CLK320 1999
Be careful, the position of the pin on those ligth are not "normal" They are position at 120 degres(approx) if your try to insert a bulb with normal pin position (180 degres) you gone broke the connector. When I've bought my CLK the 2 sockets was broked. I've buy replacement part at Bimmer.com (14.00$ each approx)
PAL |
#7 |
Drives: 2013 FIAT Abarth 500
I don't know how big your hands are but unless you have Hulk-style hands you should be able to do it all in under 10 mins without tools.
The passenger side is a little tighter than the driver side from past experiences and it takes a little practice to get the orientation and positioning right, but after a couple times of switching them out it's a simple job.
__________________
i ♥ 208 |
#8 |
Drives: CLK 320 (2001)
i had to use a tweezer .. they are nice and if u got the led, make sure they got teh canbus so it cancel the error
__________________
VIP Front & Rear Strut BarsVIP custom cold air intake 3inches K-Mac Front & Rear Camber Kit H&R Aggressive Spring & NO pads (2.5 inches all around) H&R Rear Spacers 15mm Koni Adjustable Shocks Slotted/Drilled Rotors Akebono brake pads, Custom Exhaust No Resonator 5 Spoke Benz Rims 19 by 8.5 (Dipped in Chrome) Tires 235/35/19 3% Limo Tint Halo Projector headlight with HID H7 and 30000K royal blue and HID fog light 20000k royal blue and LED side markers. |
#9 |
Drives: 2002 CLK 430
I'd like to replace mine with the LED (or a similar superwhite - the current bulb looks off from the HID's). Anyone know the size?
#10 |
Drives: 2002 CLK55 AMG
I just installed LEDs (5000K) to match the factory Zenons and love them. Simple job to install...I did it in the parking lot that I purchased them in with no tools in about 5 minutes. Look up a vendor named AZN Optics on this forum...great guy...if you are in So Cal he will meet up with you. They are around $20 for the set...I did the license plate also (a bit more work to install those).
| Tags |
| 2001, 2004, 320, 430, bulb, bulbls, bulbs, city, clk, clk55, led, license, light, mercedes, plate, replacement, super, superwhite, w208, white |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
