Sign in using an external account
| CLK-Class (W208) 1998-2002: CLK 200, CLK 230K, CLK 320, CLK 430 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 Mercedes CLK 430
tomcat07
#2 |
Drives: 2000 CLK430 Cabriolet
Be certain that the safety catch is properly engaged on the
passenger side ejector seat, and be advised that the solenoid likely needs to be replaced on the rear pop-up bullet proof shield. Other than that, mine has been problem free. Welcome.
__________________
CLK430 Cabriolet, bought it new in year 2000, Chassis# W208, Trans#722.623, Engine #113.943 |
#3 |
Tomcat07
This is precisely what I checked when I was flying A4's
#4 |
Drives: 01' S430, 08' C300,99 CLK 320 cab, 04' Q56
Welcome. If you do a search you'll see this question has been asked and answered on a few occasions. That being said, you'll notice a trend to watch for motor-mount replacement, and transmission shifting issues.
I'm only a year into my w208 and so fart it's been good except replacing A/C compressor.
__________________
![]() 01 S430 [sold] 99 CLK 320 Cab 05 E500 04 Q56 08 C300 [sold] |
#5 |
Tip: Your topic needs a better title than just your name.
__________________
#6 |
Drives: 2002 CLK430
If the car has been well kept, nothing expensive will be ready to "go out". All these cars need is normal maintenance. Here is a link to the maintenance schedule. Although, if you can't do the maintenance yourself, and you don't use an indy, a dealer will be pricy. The most expensive thing will be the cats (if they go out). Next will be the rear diff seals (if they leak). The power seat motors are $125 (part only, about 45 minutes for a DIY if you've never done it - no they don't all go out). The MAF may wear out. A real Bosch unit is inexpensive and easy to change. The O2 sensors are probably due. The plugs should have been changed twice by now. The trans fluid should be changed, but that's cheap (at my local dealer). If you can do the work yourself, this site lists several things.
Here’s a short list of CLK specific things to check. Here’s a longer list of things to inspect Here’s a list of things for the non-technical buyer I hope that helps. |
| Tags |
| 115000, 2001, 430, changing, clk, compressor, convertible, w208 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
