Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W208)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-15-2012, 02:35 AM   #1
Drives: CLK 230 Kompressor CONVERTIBLE
oz ben michael
Smile Cabriolet Roof problem
CLK 230 Cabriolet
I have a CLK 230 Kompressor Cabriolet 2000 year .
The roof's red light flashes and probably one of the switches/sensors showing the roof was still open.(Although the roof is closed)
When the roof is closed I can not open the trunk, only with the key is opened.
The flashing red light and beeps 20 seconds when I start to drive.
With the top down no problem, regular open trunk.
Probably one of the switches shows that the roof is still open even though the roof is closed.
If there is any one of you advice and can help me?
Because the problem I can not open the trunk electrically, only with a manual key or When the roof is open then open the trunk without problems.
thank you very much.
To remove this ad, register today or login if you already are registered!
ozyael is offline   Reply With Quote
Old 04-15-2012, 07:02 AM   #2
Drives: clk 230 w208
You could try a reset by disconnecting the battery, (need radio code) this some times sorts it other wise I'd just take it into a dealer.
john.m.gemmell is offline   Reply With Quote
Old 04-15-2012, 07:09 AM   #3
oz ben michael
Question Other solutions?
Quote:
Thanks for the answer
I tried it and it does not help.
Other solutions?
Old 04-16-2012, 11:56 AM   #4
trudawg's Avatar
Drives: 01' S430, 08' C300,99 CLK 320 cab, 04' Q56
I have a similar problem where the light flashes like the roof is down. Funny thing for me is, when I hit a bump or go over a uneven surface, it'll beep then all the windows will roll down like I have initiated the top. It's really annoying.
__________________
01 S430 [sold]
99 CLK 320 Cab
05 E500
04 Q56
08 C300 [sold]
trudawg is offline   Reply With Quote
Old 04-16-2012, 12:39 PM   #5
oz ben michael
I have no problem with windows, roof works fine.
My problem is that the roof is closed I can not open the trunk - only manually with the key.
And this problem I'm looking for a solution and have not yet found a solution for this, because it's very annoying to open the trunk manually with the key.
Is there something idea or advice on how I fix the problem?
Thanks and nice day
Old 04-24-2012, 09:51 AM   #6
oz ben michael
I think the problem is in the cylinder retalning bow(s.n. 2088000172) and in the switch top drive (s.n 2088202310) Adjacent to cylinder.
Does anyone can help me and guide me how to Reach to the switch and to the cylinder?
Pictures will help
Old 04-25-2012, 04:25 PM   #7
Drives: CLK 320 CAB
If your roof operation works fine, then it sounds like the electronic boot/trunk lock could be faulty, I have read on here that they have failed before.
I hope this helps
Jim
luckyjimbo1 is offline   Reply With Quote
Old 04-26-2012, 01:03 AM   #8
oz ben michael
Question
Quote:
I hope this helps
Jim
I replaced it a few months ago.
Even then there was the problem, and yet it exists.
It's probably not the problem.
When the roof is open ,all works fine and i can open the trunk, only when the roof is closed i can not open the trunk electric (only possible with an iron key open
Does something have any ideas how to fix the problem??
Old 04-26-2012, 11:56 AM   #9
Drives: 02 clk 55
A hook up to the star machine will tell you which micro switch is faulty. My guess would be the rear bow lock switch.
bobbyjo9 is offline   Reply With Quote
Old 04-27-2012, 02:04 AM   #10
oz ben michael
Smile Does anybody have an idea how I fix the problem
Quote:
Thank you for your answer.
But last week I changed the lock Rear bow & Cylinder assembly and This is not the problem (the problem existed before )
A month ago I bought this part from Top Hydraulics, I must say I am very pleased with the service of Top Hydraulics and I would highly recommend.
I had this cylinder is leaking and they sent the part I changed it and everything works fine.
Except the problem with a trunk I can not open an electric / manual, only with an iron key manually.
What is it " star machine " ??
Does anybody have an idea how I fix the problem?
Thanks a lot
oz
Old 04-27-2012, 11:51 AM   #11
Drives: 02 clk 55
Star machine (sds) is what the dealer and larger indi shops use to communicate with the cars computers.
Old 04-29-2012, 02:08 AM   #12
oz ben michael
Smile Is there something that has another idea how to help me and solve the problem of the
Thanks for the answer.
I already went to the main company of Mercedes are connected to the computer the car and worked for two hours and thay didnt found the problem I paid them $ 150 I went, they said I would leave the vehicle and it will take several days when every hour of work, not including parts cost $ 150. No parts only for the job they want about $ 1200 is robbery!
What do you think about this product?
http://www.autotoolsmall.com/mercede...ide-p-426.html
Is there something that has another idea how to help me and solve the problem of the trunk?
Old 04-29-2012, 08:24 AM   #13
Drives: CLK 320 CAB
Sounds a bit obvious but the trunk button on the remote key is working ok ? also is your electric roof button still flashing ?
Old 04-29-2012, 10:11 AM   #14
Drives: clk320 wife, s5amg sold :-{(
Thumbs down maybe better now otherwise forget autotoolsmall
I bought the above product a few years ago. Never got more than some standard stats.
luckychuckie1 is offline   Reply With Quote
Old 04-30-2012, 01:35 AM   #15
oz ben michael
1. the trunk button on the remote key is not working (the led is on When you click on the remote control button)
2. Yes the electric roof button still flashing And you hear a beep every second, there must be a micro switch which means that the roof did not complete the operation and the roof is still open - that's my problem I want to help solve the problem.
Old 04-30-2012, 12:10 PM   #16
Drives: CLK430
you may want to change the trunk lock, a couple of others had this issue and the lock itself was at fault.
Hitman0187 is offline   Reply With Quote
Old 05-01-2012, 02:28 AM   #17
oz ben michael
Quote:
I changed the lock mechanism and a few months ago.
Even before I changed the lock I had the same problem. - this is not the problem
Does something have another idea how to fix the problem??
Old 05-01-2012, 12:21 PM   #18
Drives: 02 clk 55
A dealer charged you an hour diag fee and said no faults found? My local dealer is the priciest in the bay area and THEY wouldnt even do that! You should have gotten a print out showing what was tested and how it tested. Id go back and ask for the report you "paid" for. Confirming all micro switches are operating correctly!
Old 05-02-2012, 02:05 AM   #19
oz ben michael
Smile
I went to the main garage Mercedes Home in Jerusalem.
I asked to be told what is the problem is and what it would cost me to fix the problem and of course to fix the problem.
They said that only about bidding and checking with a computer will cost me about $ 150 I agreed/
They worked and examined the vehicle for two hours and a half and they did not find the problem and told me I needed to keep the car a day or two and they do not know How much will it cost me and Charge me every hour of work.
I am very angry and spoke with the manager and asked him why I pay you $ 150 that was the reason I went to the garage. And you didnt give me an answer so he said that's how they worked two hours on the composition and charge me only for an hour and nothing could be done.
I realized that all they want is to squeeze and make me money.
If you understand Hebrew, I would send you the invoice is paid
So as you see i have no one to talk 'and in israel we didnt have professional people who understand the mechanisms of cabriolet cars and know how to fix them.
I have good content knowledge I had some problems with the roof and I fixed them all alone and still one of my only problem with unopened trunk.
Does something have another idea how to fix my car's problem?? - Please
Old 05-02-2012, 06:57 PM   #20
Drives: 02 clk 55
Well they got cha there!! without a readout your really in the dark. My best guess still involves the rear bow lock. Since this is the only lock not checked with top down but IS checked on top up, I would start there. Have you checked the wires that run down the passenger side hinge arm for the cover? They get lots of movement and have been known to break internally.
Old 05-03-2012, 02:16 AM   #21
oz ben michael
Thank you for the answer.
I replaced the rear bow lock Completely month ago .
I also checked the wires and no problem with them.
I think the problem is the micro switch that shows that the roof is still open, I have a warning sound when i start drive and the red lamp blinks.
we just have to find the damn switch!
Old 11-27-2012, 08:31 AM   #22
Drives: W209, W208 Cabrio
Hello oyael , did you find the switch ? I have the same problem...
Chuskero is offline   Reply With Quote
Old 11-28-2012, 01:25 AM   #23
oz ben michael
Smile The problem at the end was torn wires.
Although I checked the area and eventually found the disconnection of wires
Instead of wires were ripped right sleeve of the trunk lid.
You can contact me by email and I'll explain better.
It took me a year to find the problem.
Now everything works great
Send me an email if you need help and I will help you gladly
oz
Tags
2000years, 2001, 320, 430, benz, cab, cabriolet, clk, clk430, lock, manuel, mercedes, open, problems, replace, roof, space, top, trunk
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
