Sign in using an external account
| CLK-Class (W208) 1998-2002: CLK 200, CLK 230K, CLK 320, CLK 430 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: '00 Mercedes 430/55 clk cabriolet
Faster Transmission Gear Changes
__________________
" Star in the hood. " |
#2 |
Drives: CLK W208
NICE! so you have the speed shift like the newer AMG transmissions. just add paddle shift to it and you are good to go. I some what figured out the paddle shifter retro so i will be trying iyt when i dput in my 55 setup, but now with this upgrade those paddle shifts will actually work as a paddle shifter and wont have a few second delay from action to reaction. are these blue solinoids direct plug and play? ther are absolutly no need for any retro work?
__________________
#3 |
Hi Ash,
I'd love to do a paddle shift conversion but they run a bit rich for me at the moment ($900 plus trade in of your old steering wheel). I'm saving for a cool headlight mod! ![]() If you've figured out a cheaper way post it when you're done. The solenoids require no other mods just a speed-shift transmission. If you don't have one retro-fitting one gets quite expensive. As I've said the shifts are fast all the time which makes shifting at a town speeds or in traffic a bit jerky. A small fix is to use Winter mode when in stop/start traffic below 30mph as this cuts out 1st gear which you feel the most.
__________________
" Star in the hood. " Last edited by Pauljay; 04-17-2012 at 11:38 AM. |
#4 |
Drives: 02 CLK55 Cabrio
Very good info! I would love to try a drive in your car to see how it feels. My biggest gripe with my tranny is how dumb it is in the lower gears. It seems like it either shifts into second (and third) way to soon, or you have to put your foot down and lay some rubber to get it to carry first gear to a higher RPM. Their is no comparison to our BMW X3 (2006) auto trans, which seems to sense very well where you want it to shift in the rev range. Plus, the BMW is nice because if you put it in sport mode, it will automatically shift at redline. Though I baby my AMG too much to be shifting at redline very often.
So, I think your mod would be a good compromise. I've always wondered why they don't let the driver simply choose at what RPM they want the car to shift into a higher gear.
__________________
#5 |
UncleSlam
Loving the Avatar! The transmission doesn't change it's settings, unfortunately the learning programme is still there. The changes are just faster. When I'm driving I could get up to 40mph and I'm in 3rd gear already. When driving fast the transmission will hold on to gears longer unless I manually change up. At speed the changes are really slick. Because the changes are quicker you hold on to the power more and my car feels so much faster for it! Janexiong I use a Sprint booster and love it! My friends think it makes the car too sensitive at slow speed but I'm used to just tickling the throttle and riding the torque wave.
__________________
#6 |
Hold on a second, I just read in another post that "Blue tops are shift solenoids that are used in the AMG's", so does that mean my AMG already has these?
__________________
#7 |
No!
Blue Solenoids only came into effect on later AMG cars from '05 onwards. Most Speed Shift transmissions have Brown tops.
__________________
#8 |
Drives: 2001 CLK55
hey pauljay:
how are you liking it so far? is the shifting too harsh? have you thought about doing a tcu tune?
__________________
17" Monoblock II Front/18" Monoblock II Rear AZN Optic LEDs Porscheleds Cluster LEDs Secondary Cats/Resonator Delete AMG OCI #26 |
#9 |
Hi Slowsky.
I'm loving it still. The transmission only jerks when going up or down betwwen 1st and 2nd gear when moving slowly. A bit like engaging drive from neutral without your foot on the brake. When in traffic I use Winter mode to do away with 1st gear. Normal driving is smooth and acceleration is great! If anyone can stump up the oil for the trans twice, I would recommend that they try this mod and if they don't like it put the Brown tops back in. I've now done 700mi and I'm sure the trans has done all the adapting it's going to do (if any) as I haven't noticed a change. I will try the TCU mod just got to save for it!
__________________
#10 |
Drives: 2001 CLK55
im curious if the tcu can mimic the same effect or will having the blue tops along with the tcu make it snap faster without the jerkiness...
__________________
#11 |
That's what I want to find out. If it gets quicker or smoothes the jerk from 1st to 2nd. Hopefully both!
__________________
#12 |
Drives: CLK 320 (2001)
Gonna look into it and thank u
__________________
VIP Front & Rear Strut BarsVIP custom cold air intake 3inches K-Mac Front & Rear Camber Kit H&R Aggressive Spring & NO pads (2.5 inches all around) H&R Rear Spacers 15mm Koni Adjustable Shocks Slotted/Drilled Rotors Akebono brake pads, Custom Exhaust No Resonator 5 Spoke Benz Rims 19 by 8.5 (Dipped in Chrome) Tires 235/35/19 3% Limo Tint Halo Projector headlight with HID H7 and 30000K royal blue and HID fog light 20000k royal blue and LED side markers. |
#13 |
Drives: CLK W208
Pauljay, i figured out the Paddle shifter situation that we talked about. I'll send you some links and pics. Also can you tell me if these solinoids would be a direct replacement for the 55 transmission too? because since mine is a 320 i'm changing the transmission, diff and the drice shaft too since they are all the 4 point contact with the flex discs.
__________________
#14 |
Drives: 2001 CLK55
i talked to jerry and he said he can tune the solenoids for smoother shift...the thing we don't know is if its a physical issue why our transmission can't shift fast or a coding issue.
vipclk320 hats off again to you for researching paddle shifting for our age old platform....really admire what you have done with all your projects......is it a hard conversion? the blue tops are for the 55 transmissions 2003 and older....
__________________
#15 |
Drives: CLK W208
did you mean 2003 and newer? because from my understanding they come on the maybach and sls. also i know that the 55s even on the w208 use the 600 trans which is oof of the v12s.
__________________
#16 |
Drives: 2001 CLK55
you are right, i meant we have the brown tops, and blue tops came from 2003 and newer...
__________________
#17 |
Hi Ash.
Nice one for the paddle shifter! Please pass on the details. All Speed-shift transmissions before 2003 had brown tops. After that were cross over years, you had to check your chassis number to find out which you had, then from '05 onwards AMG transmissions had them. They are a direct replacement for Speed-shift Brown solenoids. Slowsky I think it's both! Once I have the mod done I hope to confirm this.
__________________
| Tags |
| 208, acceleration, clk, faster, gear, hard, jerks, make, mercedes, neutral, shifts, tiptronic, tranny, transmission, w208 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
