Sign in using an external account
| CLK-Class (W208) 1998-2002: CLK 200, CLK 230K, CLK 320, CLK 430 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: CLK 320 (2001)
__________________
VIP Front & Rear Strut BarsVIP custom cold air intake 3inches K-Mac Front & Rear Camber Kit H&R Aggressive Spring & NO pads (2.5 inches all around) H&R Rear Spacers 15mm Koni Adjustable Shocks Slotted/Drilled Rotors Akebono brake pads, Custom Exhaust No Resonator 5 Spoke Benz Rims 19 by 8.5 (Dipped in Chrome) Tires 235/35/19 3% Limo Tint Halo Projector headlight with HID H7 and 30000K royal blue and HID fog light 20000k royal blue and LED side markers. |
#2 |
its a 115 amp, the bearings are probably going out in the alternator if its noisy.
9 times of out 10 its the voltage regulator that is bad. |
#3 |
Ty took the car to advanced auto parts like what VIP recommended to test it out and all checked fine and alternator failed. They said my starter ll die in 5 months
__________________
#4 |
Drives: 2002 CLK430
Almost all the time it's the voltage regulator. The voltage regulator is a normal wear part on these cars. If you have the alternator out, pull the regulator and you'll see why. Here are some instructions.
Even if it were the alternator itself, you can have it rebuilt. Just check the yellow pages / Internet search for a starter/alternator rebuilder near where you live. The last alternator I had rebuilt cost me about $80 and it took 90 minutes. Although I have SERIOUIS doubts that anything except the regulator is bad. |
#5 |
ty marcus
__________________
#6 |
Brother it was 120 amp. Had to return the alternator and they ll fed ex me new one Tomorrow
__________________
| Tags |
| 2001, 2012, 320, alternator, batteryalternator, clk, clk320, clk430, mbworld, nalternator, noise, rebuild, regulater, removal, voltage, warning |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
