Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W208)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-26-2012, 02:03 AM   #1
Pancho's Avatar
Drives: 2000 CLK430 Cabriolet
Cabriolet Owners - Myth or Fact: All Cabriolets eventually develop a shimmy at 60MPH?
Cabriolet Owners - Myth or Fact: All Cabriolets eventually develop a shimmy at 60MPH ???
Looking for comments from Cabriolet owners--Cabriolet owners.
Have read/heard that this 60 MPH shimmy in steering wheel is a characteristic of the W208 Cabriolet. I have the shimmy. Replace parts, lessens, or goes away temporarily, then it's back. Seems there is a consensus that this is a characteristic inherent to the cabriolet.
Any Cabriolet owners have an opinion/Info./experience Re. this ?
Thanks.
To remove this ad, register today or login if you already are registered!
__________________
CLK430 Cabriolet, bought it new in year 2000, Chassis# W208, Trans#722.623, Engine #113.943
Pancho is offline   Reply With Quote
Old 04-26-2012, 03:31 AM   #2
Drives: clk 230 w208
Mine only does this when its due for an oil change, so I suspect engine mounts. I haven’t had a chance to investigate further as yet.
john.m.gemmell is offline   Reply With Quote
Old 04-26-2012, 03:49 AM   #3
I have also been told that sway bars at front and back would stop it. Because they will stop the twisting across the chassis.
Old 04-26-2012, 11:06 AM   #4
Drives: 02 clk 55
Without the roof, any structure will suffer some degree of weakness. An aging chassis in cabriolet form will show those weaknesses more dramatically than the coupe brother. Cowl shake is common to experience but in a straight line smooth road you should not have a shimy. Mine would knock your teeth loose when I first purchased but now is smooth as glass. LCA bushings, ball joints, and flex discs were 95% of my problem. Roof up will stiffen the car but roof down will also allow the whole chassis to absorb and disperse the movement. There is a trade off to all that sunshine!!
bobbyjo9 is offline   Reply With Quote
Old 04-26-2012, 12:48 PM   #5
trudawg's Avatar
Drives: 01' S430, 08' C300,99 CLK 320 cab, 04' Q56
mine does it. Still havent figured out if it's a myth or fact, but it really sux. I either have to speed (80mph) or drive like an old lady (55mph)
__________________
01 S430 [sold]
99 CLK 320 Cab
05 E500
04 Q56
08 C300 [sold]
trudawg is offline   Reply With Quote
Old 04-28-2012, 10:45 AM   #6
Drives: E55
I have yet to experience this...?? I have an 03 430cab w/ low miles, but I've never had any shimmy or vibration.
whitee is offline   Reply With Quote
Old 04-28-2012, 02:31 PM   #7
Drives: 02 clk 55
Quote:
Its kind of like talking about the two types of motorcycle riders... Those that have been down and those that will be going down! Rubber ages and bushings will degrade... sorry to say but you WILL be experiencing those pesky vibrations at some point.
Old 04-30-2012, 03:56 AM   #8
Drives: 2000 CLK 430
105,000 miles and no noticeable shimmy that I can recall. I will take notes tomorrow.
I will say though, that at 80mph ....she glides like butter. Top up or down.
nicgentile is offline   Reply With Quote
Old 09-19-2012, 10:12 AM   #9
Drives: 2001 CLK 430
I just bought a sweet 2001 CLK430 Cabrio, 111,000 - excellent condition. They guy who had it before was maniac for service and took it to the dealer every time he heard a noise. Bought him a beer for that!
EXCEPT the shimmy @ 60 and then at 30mph.
FIX - I swear on a stack it was the tires, balance and alignment (road force / F&R) that took 95% of the shimmy off. It was so bad it'd shake your teeth like you were having hypothermia. I put on Continentals at first but had to pull them off after about 100 miles b/c they did not fix the shimmy. The tires is not a good one for this particular car. On other cars sure - but this car is really *****y about the shoes you put on it.
So i put on new Michelin Super Pilots - Butter. Super smooth. I SWORE UP AND DOWN THE BLOCK THAT TIRES COULDN'T NOT BE THE PROBLEM. NO WAY. They were the majority of the problem. Really!!! Tires. After weeks of trying to chase down the problem it turned out to be tires. I wanted to hurt myself. Went to 2 dealers and MBZ shops and I wasn't in the mood to be shaken down by either.
The last 5% is in the struts, bushings ball joints and control arms. They're almost sort-of ready to replace, and I'm just doing this early because I'm neurotic. I still need to replace the struts and the control arm bushings which I'll do all at one time for the front in a few weeks because I'm trying to put this car back into perfect condition. Mint factory.
The tires. I just did this 2 days ago and today is Wed. Sept. 19.
birkie is offline   Reply With Quote
Old 09-19-2012, 03:21 PM   #10
jserio's Avatar
Drives: 1996 SL 320
Mine does not seem to do it throughout the speedometer. Not that I've noticed anyway.
__________________
Joe Serio
Garden Grove, Ca.
1999 CLK320 Cab
2011 Honda Civic ( daily driver )
jserio is offline   Reply With Quote
Old 09-24-2012, 05:39 PM   #11
JayDee4711's Avatar
Drives: 2003 CLK430 Cabrio, 2004 E500 4Matic Wagon
+1 on the impact of the tires. At a mileage of 72,000, mine does not shake. Except ... if it has been sitting in the garage for a week or more, it will shimmy at 60 mph for tens of miles or until it has had a chance to sit on another spot of the tires for a few hours.
I put on a set of Eagle F1 Asymmetric XL tires about 10 kmiles ago. That may or may not have brought a little change compared to the cheapo rubber that was installed before. But it is definitely there.
OT: The Eagle F1 rocks in all other respects!
JayDee4711 is offline   Reply With Quote
Old 09-25-2012, 09:42 AM   #12
Drives: CLK 230K Cabriolet
marcoalza
Quote:
You're joking right?
Iknow you posted this in April but 25 days late for April Fools!
__________________
CLK 230 Cabriolet
2002 Final Edition
marcoalza is offline   Reply With Quote
Tags
2002, 320, 430, 55, 60, cabriolet, chasis, clk, convertible, cowl, drive, mb, mph, myth, shake, shaking, shimmy, top
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
