How to remove rear view mirror from windshield header?
The rear view mirror is loose in my convertible where the mirror connects into the windshield header. How do I remove the whole mirror assembly so I can figure out how to tighten it?
-J
-J
so on the vert you need to remove the front plastic trim where the mirror stem meets the windshield. Next remove the light lenses and pull out the 4 crews to lower the overhead console. I found it easier to disconnect it completely. Then take a pair of adjustable pliers and grab the top of the stem and twist 90*
Looking at the mirror I found that the clip that holds the mirror stem to the windshield was stretched a bit. So I took a pair of plires and squeesed closed the clip just a touch. Then reinstalled the mirror by sliding the stem to the mount and turning with the pliers 90* back into position.
No more mirror shake over bumps.
03' CLK320 Cabriolet W208
I want to Bump this thread. I have an 03 CLK 320 Cab (208). I've gone through a lot of different threads and have noticed I don't have the plastic trim cover for my rear view mirror & it shakes like crazy, rattles, moves, and over all makes me friggin' crazy!! So...do I have to have the trim piece to stop the rattle or can I just twist it 90*? Also is it 90* clockwise or counter clockwise? I'm about to go postal & there are NO pics to help in the process.
It's been so long I don't remember exactly how it came off, but the basics are you grab the top of the shaft where it meets the windshield with a pair of channel locks and twist. What I found was the clamp was stretched out on the mirror causing the vibration. I squeezed the clamp slightly with a pair of needle nose and reinstalled. Worked great except the problem came back about 6 months later. So on my second attempt, I squeezed the clamp and reinstalled, but this time I filled the whole clamp with silicone which basically glued it in place.
Ain't moving now.
Ain't moving now.
