Front Wheel bearing
CLK430
Front Wheel bearing
While getting my tires changed, the guy said, we shall not do any wheel alignment, as there was lots of play on my front two wheels.
12-6 o'clock
9-3 o'clock
both revealed quite a lot of play.
He suggest me to change the wheel bearing.
Is this a DIY project?
Is this the part
https://www.autohausaz.com/search/pr...0Bearing%20Kit
What else is required in terms of parts to be purchased?
Cheers
12-6 o'clock
9-3 o'clock
Is this the part
Cheers
I would just pull it, repack it and tighten it back to spec to see if the play goes away before spending cash on new bearings. The bearings are relatively cheap though.
You can usually remove the seal without damage if you're careful. If you botch the seal though, just buy a whole new kit.
I'm sure there's a diy here if you search.
I changed mine like a year ago then the other side like month and a half ago.
One side, I had to change the entire assembly and other side only bearing.
make sure u libricate the hell out of the bearind and inside of the hub...
its simple..
This is a DYI from a diff board:
http://www.benzworld.org/forums/w208...ement-diy.html
its simple..
