side mirror has stopped dipping in reverse?
"SOLVED" side mirror adjustment for dipping in reverse W208
Hi Guys
The switch control is on the passenger side but it does not move when reverse is engage? The mirror can be adjusted manually normally however?
Is there any fuses, perhaps a lose connection?
Okay guys read through some posts for other models and manged to find a way to fix the non-dipping side mirror for Mercedes CLK W208
Obviously make sure your mirror switch is on passenger side. (If on drivers side mirror dipping is cancelled).
With mirror switch on passenger side:
1- Turn key to position 2
2- Adjust mirror down so you can see kerb for reversing etc.
3- Press Green store button on drivers door control next to the seat adjustementfor a couple of seconds, then within 3 secs press the mirror control again just once in any direction, mirror is now stored.
4- Wait 17 secs mirror will return to normal position.
5- Select reverse and test to make sure it dips ! DONE.
